maarkmohamed
- Joined
- Jan 10, 2019
- Messages
- 116
Hey just a quick question about bypassing bms discharge and only using it for charge. This was talked about on a different thread but i just had one question. The diagram below for bypassing the bms shows that you connect the charge positive and negative directly to the battery pack and the only thing you connect from the bms is the sense wires (or w.e they're called thats equal to your series number.) My question should i connect the P- to the charge negative? Or like the diagram shows connect charge wires directly to battery pack? With the charge negative not connected to P- will it still be able to balance the pack?
Thank you
http://www.vanderworp.org/Battery%20Management%20System%20BMS
Thank you
