I don't mess much with V2's these days, but let's see what we can do...
I just shot up a V3 with V2.4 code - which I believe is the current shipping V2 version and whose menus show a bit of mixed parentage from the V2.2x and V3 models. The 'Advanced Setup' as the last entry after pressing the right button 2 short presses after entering Setup.
- BASIC SETUP
- Set Units
- Set Wheel
- Set #Poles
- Speed Limit
- Amps Limit
- Main Display
- BATTERY SETUP
- Chemistry
- Set Capacity
- Num Cells
- Low Volts Limit
- ADVANCED SETUP
- Set Range
- Set RShunt
- Zero Amps
- Volt Calibrate
- Averaging
- Serial Output
- PSGain
- IntSGain
- InAGain
- IntVGain
- ITermMax
- ITermMin
- Max Throttle
- Set TotDist
- Set TotAhrs
- Set TotCyc
- Aux Volatge
- Aux Thresh
- Vshutdown
A long press on 'Advanced Setup' gets into the advanced parameters and 'Zero Amps'.
- So - starting at the beginning - what is the model number (e.g. 2.4) displayed on the splash screen when your CA boots?
- What are the menu items you have in Setup?
- Also - FWIW - Do you have a programming cable?
EDIT - Ah - missed the part about it being in the drawer for a year...
Re-flashed with 2.3 which I believe was the shipped version a year ago.
On entering setup I get:
- SETUP
- Set Units
- Set Wheel
- Speed Limit
- Amps Limit
- Low Volts Limit
- Main Display
- ADVANCED
- Set Range
- Averaging
- Set RShunt
- Zero Amps
- Volt Sense
- Set #Poles
- PSGain
- IntSGain
- InAGain
- IntVGain
- ITermMax
- ITermMin
- Max Throttle
- Set Ratio
- Serial Output
- Set TotDist
- Set TotAhrs
- Set TotCyc
- Aux Volatge
- Aux Thresh
- Vshutdown
This is based on the original 2.2x layout.
Does this look like yours?
