John in CR said:
Thanks for confirmation of that AW, though I'm still considering a diode near each controller on the throttle line to block voltage differences between the 2 controllers, since other than batt +/- it is their only common connection. Is their anything wrong with that?
The diodes won't necessarily have *exactly* the same voltage drop, so each controller may have slightly different response to the same output from the CA. Plus you have to measure the voltage drop you do get, and then add that to the output voltage you want from the CA for zero and full throttle, so it'll actually get the correct voltage at teh controllers.
I used a diode on a test setup of the trike so I could parallel the throttle and the CA's throttle output (controled only via PAS), so I could have a PAS with a speed limiter (switchable to three levels via presets) that would let me just pedal along and have the bike just go 20MPH, or 10MPH, or 5MPH, and not worry about it (without using any form of "cruise cotnrol"), but still have a non-limited throttle override for those few moments here and there that require it. I had issues trying to get the voltage worked out so the CA would be ablet o correctly control the motor. I am not sure I ever got it quite rigth, because it seemed like every change I made to the levels to get it right changed the loss across the diode, so it was always too little or too much. IIRC I eventually just lived with it being higher than needed, but not high enough to cause the controller to error out.
(at this time I am now running that motor's throttle direclty thru the CA, only, along with PAS, and use the other motor's throttle completely separate...when I eventually get around to rewiring eveyrthing to have a throttle bypass, I'm going to use op-amps to isolate everything from everything else, with adjustable gains so I can hand-tune it with potentiometers ratehr than dicking around in the CA menus trying to get it right over and over and over....)
I see it on the CA3 screen with about the same timing as the throttle ramp up and down setting, but only when the throttle is connected to the CA3. It goes from about zero to 1.4V, and near the upper end starts to spin the wheel.
If it *only* happens when the throttle is connected, then it kind of sounds like an electrical issue (ground loop?). Does it happen when the throttle is connected to teh CA input, but with the CA output *not* connected to anything?
Is the throttle *only* connected to the CA, not anything else, for any of it's wiring? (including grounds)
If the throttle input and output levels are setup for the specific throttle and controller ranges you've got there, then the CA shouldn't output anything higher than whatever you've set for the "off" output level, until the input receives a level higher than it's "off" (minimum) setting.
There's no interference, it's just each of the CA3's, a 20s battery, the TTL serial wire from ebikes.ca, and multiple proven to work USB ports on my computer.
Can you try it with a lower voltage battery, like 10-14s? The CA should be good for at least 100v, but perhaps there's something going on with the regulator at 20s that might not happen at lower voltages, causing a serial problem.
