This subject is getting tiresome. But, a few more thoughts and facts...
My powered two wheeler halcyon days were long ago and far away. beginning in about 1957 and ending in about 1962 I devoted 30,000 to 40,000 miles to intensely enjoying two wheel transportation. A Sears Cushman, a Sears Cruisaire and then a Triumph T110 TR6. Very close to the same mileage on each one. That is my data base. So that is my data mine when I dig up first hand knowledge of what it is to ride on two wheels under power. it is my sadness that my data is not more recent vintage (though electric bikes have re-lit my fire! ). I am very sad that somebody may belly ache about my old archaic bikes and information but it is what I have to bring to the table. Be reminded that good data does not go stale and turn bad just because it is old.
Where to start.
Every time I recheck the factory statistics I seem to hit on a different reference source that has the factory rated horsepower one or two different. My most recent source said...
1958 Triumph T110 40 HP
1958 Triumph T110 TR6 42 HP
1960 triumph T120 Bonneville 44 HP
In a small number of illegal, dangerous, impromptu drag races on the street my TR6 was a EXACT even match to my best ole friend Ray's box stock Bonneville. We always started from a rolling start to save on burned up tires and clutches and ended when one or the other shut down when satisfied of how the race was going to turn out. The slowest shut down was about 80 MPH and the fastest was about a little over the ton, maybe 105 MPH. One time I would be ahead by 5 feet and the next time Ray would be ahead by 5 feet and a time or two we were exactly nose to nose. So I say that my hot rod TR6 was exactly mechanically equal to the box stock Bonny, 44 HP. Anybody not getting this?
DO NOT DRAG RACE ON THE STREET LIKE WE DID! WE WERE YOUNG AND WILD AND FOOLISH! BE SMART!
It has been said that factory ratings are wildly inaccurate. If this were true, the factory rating would be TOO HIGH because that is what causes sales of motorcycles, high power. Factory ratings TOO HIGH would screw the critic's case against my truthfulness and accuracy. If the factory rating was TOO HIGH then the Bonny and my TR6 would have had say, 35 HP whereas my critic has WAG guessed first 135 HP and then 54 HP.
It has been said that speedo reading are notoriously wrong. I have read many old motorcycle magazine road tests of many limey bikes using Smith Chronometrics speedos from the late 50s into the early 60s and never read of one found to be off more than 1 or 2 per cent at 100 MPH.
The accurate math formula for Aero Drag is based on 1/2 (velocity squared). When the formula for Power is additionally considered, Power can be described as based on 1/2 (velocity cubed). AERO DRAG IS NOT BASED ON VELOCITY SQUARED. POWER IS NOT BASED ON VELOCITY CUBED.
Aero drag is based on 1/2 (velocity squared). Power is based on 1/2 (velocity cubed). Does anybody get it? Does my critic understand that the 1/2 cannot be left out? When drag and power are calculated from first principles, simple squares and cubes will produce answers wrong BY MORE THAN 10 PER CENT :wink: .
However when comparing drag and power from one velocity to another velocity, the 1/2 does drop out. Therefore my comparison of power at 39 MPH to power at 117 MPH was valid.
Back in the day, the rolling drag from different tire pressures was very obvious. I could easily feel it when pushing my scoot or when riding. I knew that lower pressures could give better traction in cornering, but usually chose higher pressures to wring every MPH out of my scoots and also later in my TR6 by lower rolling resistance. In my scoots higher pressures gave me 2 or 3 MPH more speed. My wildly wrong
speedo would always show maybe 41 MPH on lower pressure and maybe 44 or 45 MPH on higher pressure.
So I am seriously suspicious of the critics who use a "standard value" for a rolling friction coefficient when they calculate rolling resistance. I know from first hand experience how greatly it can be manipulated and how much of a difference it can make in velocity. I believe that rolling friction can be made to be much lower than the "standard value" and back in the day I always kept my Turnip's tire pressures on the high side. It is my opinion that my moto's rolling friction was much lower than my critic has imagined it to be, and that my calculations leaving out rolling friction are not seriously innaccurate at higher velocities.
I think that I have beat this subject to death and that I have been a co conspirator to hijacking this thread too long now. I don't care how many snide insults and or lies some critic may write, I am gone, to some other NICE thread maybe.
