omegagamer89
1 W
Does anyone know if you can safely reverse the polarity on this type of motor controller? (red to black and black to red, instead of the current setup of red to red and black to black)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251147109564
Ok, so I got all my bugs worked out, and I hooked everything up and mounted the motor to the bike frame, only to discover that, when I turned it on, the motor spun the wrong way, and would basically have had my bike moving backwards.
Now, I CANT move or flip the motor around, due to the fact that
A) The gear on the motor has to stay on the right side of the bike, because the gear on the wheel is on the right side
and
B) flipping the motor around and then moving it farther to the right so that it spun the right way would cause the motor to stick out far too much.
Its hard to explain without seeing it, I think.
Anyway, the bottom line is, I CANT move or flip the motor, so I HAVE the make the motor spin the opposite direction. I thought maybe I could do this by reversing the polarity of the connection between the battery and the motor controller (linked to above) but Im pretty sure this would burn out my controller.
Does anyone know if this is the case?
Also, what about if I reversed the polarity of the connection between the motor controller and the motor? Would that work?
Any help is greatly appreciated.
and
