ScooterBill
- Joined
- Oct 17, 2022
- Messages
- 10
This is a continuation of my previous post, where order a KT36/48SVPRK-SLS02G controller and couldn’t get it working on my scooter. Ends up I received a faulty controller. So, I have no received a replacement that seems better than the 1st one but I cannot get it to work with my setup either.
I have a 3-wheel mobility type scooter with a 750-watt 48-volt direct drive brushless motor (front wheel). It had a generic controller with reverse and no display. Link to old controller https://www.amazon.ca/Motor-Brushless-C ... 174&sr=1-3
I wanted to upgrade to a better controller with a display so I bought a new KT36/48SVPRK-SLS02G controller with a KT-LCD8H display. Link to new controller https://www.amazon.ca/Brushless-Control ... 142&sr=8-1
Everything will work with the old controller, so motor and throttle are fine.
I have hooked up only the basic connections needed. Power, throttle, motor wires, 6-wire phase connector (no signal wire, white wire), electric lock - jumpered, have tried with and without the display (display plug bypassed without the display) and get nothing. Motor doesn't spin or even try to start.
When using the display, the display does turn on. The display shows 52 volts battery voltage. When the throttle is turned “Throttle” comes on above speed display. I have 52 volts at power connector, 52 volts at electric lock connector (jumpered 52 volts on both terminals). I get 5 volts on red and black terminals on throttle connector and between negative and the signal wire I get from .8V to 3.4V as the throttle is turned. I also get 5V from the black to each hall wire (green, blue and yellow) on the 6-wire connector. And obviously no output on the phase wires. Again, everything works if I put the old controller back on.
Other thing I have tried is turning on “Walk Mode” this gives a “Motor Position fault sensor!” error on the display. Anyone know what this is? Tried a google search and not sure if this is referring to the hall sensors or would it be because of not having a speed sensor in the motor?
I have attached a picture of the settings on my controller. Can anyone see if any of these are wrong? Or does anyone have any extra troubleshooting tips or ideas of what may be wrong? Can’t believe I would have received another faulty controller, but am at a loss.
