etriker
CamLight said:Teh Stork said:Edit: well, after plundering more about capacitor role - I'll admit that only counteracting inductance is a too brave a statement - they're certainly used for many applications. Merely ment to point out that the role of the capacitor is to "smooth voltage" in most cases and that it, sort of, works exactly the opposite of a inductor. As for cap on a battery, no use - commercial chargers don't use them either, I've checked. You'll need a hell of a capacitor to make a difference.
I definitely agree that you need caps of several hundred farads or larger to make a difference in an e-bike app. Big, heavy, expensive and not worth it in that application IMHO. And you need HUGE cap banks for transportation uses (bus, railroad, etc.), but they are used. And (ultra)caps are used in parallel with batteries to provide better low-temperature performance than battery-only systems with pulsed loads. Even very high performance LiPo's lose a lot of their capability at low temps.
Additionally, small caps are used extensively in parallel with a battery in energy harvesting applications to provide the initial current burst to an intermittent load. This keeps the battery from having to supply all of this initial burst and measurably increases the battery's run-time since these batteries often have very high ESR and waste a lot of power if required to source current for larger pulsed loads. This is critical for remote sensors and other devices that use energy harvesting for storing power and need every electron they can find/store.
And every single commercial charger based on a switching power supply circuit (i.e., a LOT of them) uses capacitors on its input and output for ripple smoothing and as part of the compensation network that stabilizes the circuit's output when the load changes (transients). And also for decoupling/bypassing and charging-timeout functions too. They're not huge caps, but they are caps...and they're used in commercial chargers.
And an ebike controller is a switch mode power supply with caps in it.
