deardancer3
Not to feed the "chain drive vs. hub motor" debate monster.
(I have spent my discretionary time for the last week chasing a shifing problem on my Cyclone GRuv feet forward ebike. this is what I have found)
You know that chain drives make life harder on your chain, and hub motors make life easier. Full e-power acceleration on a hub motor drive with a shifter that takes five seconds instead of one is no big deal, but on a chaindrive it is a BIG deal)
If you have an extended length bike (Crank forward, Electra, Semi recumbent, etc) with a longer chain run, long convoluted cable runs, and a chain drive motor, you might know the challenges of keeping the index gear system shifting well. I know some folks with non motor recumbents that have just gone back to non-index gear systems due to the time spent "with a wrench", and this might be a choice for some with motors.
The crux of the shifting problem is when you up shift to a higher rear gear (smaller rear cog), the Derailler return spring is what usually drives the Derailler to the outside, and this has to overcome the friction drag inside the shifting cables. The longer and more convoluted the cable run, the more your ride in bad weather and in dirty conditions, and the longer you go with original cheap cables, the more of a cable friction problem you have. (Fair weather riders with hub motors and easy cable routing on nice bikes dont have to worry for nearly as many miles)
You can bet those cheap OEM shift cables were not Stainless steel, nor did they have weather proof fittings. And maybe you got one of those new low spring rate Deraillers because people complained it took too much effort to downshift. And maybe the guy that assembled your bike did not catch any manufacturing defects on the cable housings, and maybe he did not route the cables the best, but hey it worked on Day ONE, who cares about day 200? And you can bet that (after you cant get the thing to shift right) your local bike shop is not going to be much help on your chain drive shifting problem.
Yeah the LBS has various quality cable pieces for standard length bikes, but not the parts nor the experience on long chain and cable runs, except the attitude of "SWAP EVERYTHING" because it generates money for them.
What to do? Read Sheldon Brown's principles of Cable routing and installation and inspect your old system for problems. Measure your ideal cable run. RIGHT NOW go shopping for a high quality extended/TANDEM length Stainless STeel rear Derailler cable, Find someplace where they have good all weather housings and fitting for that cable. Buy a good cable cutter, they are not cheap. Check your chain for wear and length, Lube and clean if its ok. Clean and lube the Derailler.
If you do this stuff now, you can probably get by with about $60 including the cable cutter and do it on your own time table.
Wait till its too late and you may have to drive 60 miles and back twice to find a guy qualified, wait a week, and pay him +$250 as he swaps everything (cables, housings, shifters, Derailler - everything at top retail price for hard to find parts and labor). He will find something imperfect about everything.
Shifters, up on the handle bars, dont go bad much, as they are not down by the road with the mud and blood and the gunk; Just rain. But Cables and housings, like chains, are replaceable items, like BRAKEPADS.
Here is what All I have found wrong; Bad cable housing fitting- housing wire sticking out, bad housing fitting- cut at bad angle, bad cable routing under bottom bracket- kink, too sharp of a bend by Derailer due to too short of a cable inner wire, derailler filthy, chain too long by 6 links (my fault), Derailer pulley wheel too much sideways slop- manufactuirng defect.
If you dont want to do this stuff or dont feel competant, find a good tandem or recumbent shop and buy lunch for their best wrench, dont talk shop unless he wants to.
Comments and other hints welcome. (except for the hub drive guys saying "I told you so")
D
D
