Zenid
In my experience, peak voltage of an 72V SLA bank settles quickly to around 78-79V. I've run experiments a couple of times taking regular readings during the discharge of a battery bank, then plotting it out to get a discharge curve. The discharge curve of a lead-acid cell typically goes something like this:wesnewell said:Do you understand that a 72V SLA battery pack in good condition will charge to over 80V? That's why it shouldn't be rated as a 72V controller using 75V fets. These aren't batteries, and the ratings aren't nominal ratings.
Though peak charge of a nominal 72V bank may just crack the 80V mark, voltage rapidly drops and plateaus, with most of the discharge spent somewhere between 78 and 72V (though obviously you can discharge them further if you really want). It therefore spends hardly any time in the 80-84V window that that my LiFePO4 occupies through most of its cycle.
I've already explained ad nauseam how ratings given to components are ultimately always nominal, because the rating always makes certain assumptions about how the component is being used, what the operating temperatures are, and countless other factors.
