Charging cable off battery the thing that clicks into charger exploded
pw2000
my charger no longer charges battery any more after it exploded.
can I charge battery from Xt60?with car charger and crocodile clips?
so I can use bike until new battery arrives.
or does battery just need a new adapter on end of charging wire?
please help
Wow, exploded?!! Good thing you’re OK. It may be repairable, but batteries are dangerous, so accurate/detailed information would be required before advising on how to repair it safely. I think you should wait for the new battery to be safe, since exploding parts sounds serious.
Alligator clips on a XT60 connector? Those XT60 are pretty small, the alligator clips would be so close together it would scare me. One little slip and it could short out easily, then you could experience your second explosion.
The only way I can imagine a connector of that type "exploding" and damaging a charger, battery, etc., is if it were connected backwards, + to - and - to +, or the connector was wired backwards.
Other connectors with enough exposed metal that could be shorted by the other half of the connector (like RCA / phono, some barrel types, etc) could do it by directly shorting + to - on the exposed-pin half of the connector with the exposed metal of the ohter half, but the XT's dont have exposed metal on both halves to do this.
As for using a "car charger" on a battery, if it's not a car battery, you wouldn't want to use a car charger on it, regardless of connector type.
You need to use the correct type and voltage of charger for whatever battery it is.
Since you don't provide any details about the battery or charger, we can't help you find one that would work.
Note that if it is a lithium battery with a BMS, it's fairly likely that a backwards-connected charger exploding it's connector would have also damaged the BMS (at least the charging port, and possibly other parts).
