ymd said:
From all the discussions and seeing the setups of "footloose", I think I will be happy with either systems. In terms of long term reliability for daily long commute, I gather that MAC setup has some edge. Therefore, I am inclined to order a MAC 8T kit from Paul.
Yep, the mac will suit you well. A bridge climb wouldn’t stress out the mac.
Both the hub and mid drive have basically the same low center of gravity. I don’t find the weight on the hub to be something I notice (unless I’m picking up the bike, or bunny hopping!).
FYI – unlike stated above, amps do not add any speed (they add torque). Voltage adds speed.
Mac specs at 36v (multiply by 1.39 for 50v):
6 turn high speed motor - 400rpm loaded at 36V; 6T - 45kph (28mph)
7 turn high speed motor- 350rpm loaded at 36V
8 turn standard motor - 320rpm loaded at 36V; 8T – 39kph (24mph)
10 turn torque motor - 255rpm loaded at 36V 32kph (20mph); 10T – 32kph (20mph) (STD KIT MOTOR)
12 turn low speed extra torque motor - 200rpm loaded at 36V; 12T – 25kph (15mph)
(FYI, I go 25miles @25mph on 9.5Ah battery, but I’m on a pretty efficient low current road bike.
As I recall, my mountain bike was good for about 20 miles on the same motor/battery)
Important for your design: Go to the ebike.ca simulator to verify your speed/range/etc. FYI, that motor/controller (8t or 10t) should not overheat unless you are using full throttle for long periods of time under 15mph.
Simulator shows the 10T cruising at 24.5mph with a range of 32miles (using 572 watts), and the 8T cruising at 29.1 mph with a range of 22 miles (using 925 watts). (that is what speed does to range and power))
Take a look at this power graph for your design:
Commuting:
I do like hub motors for commuting. I actually broke a chain on my hub motor bike, and just “coasted” many miles home on the motor only. Reliability wise, I can pedal, use the motor, or use both. That is the beauty of redundancy. It’s a good commuting setup (where serious hills are not an issue).
Personally, for me, tire flats are pretty rare, and usually occur with skinny tires getting pinch flats. I do have a slime filled tube on my mountain e-bike and managed to get a huge nail in the tire. Took me a couple of days before I realized the nail was in there. Nothing but a large nail or screw gets through a good tire, making flats a rarity.
