If it's 12-72v, it should mean that you can power it directly from your main battery (assuming that is within that range). But you should probably verify that's what they mean first.
As long as it's output signal is a standard "open collector" type, where it is floating, no voltage output, when off, and grounded when on, it would be compatible with any typical ebrake input.
Best guess for the high voltage requirement vs 5v would be if it was intended for a scooter or something that uses a 12v+ lighting system....
