Hi, I’m new to the forum and appreciate your help. I searched through the forum for an answer but didn’t quite find the info i needed.
I’m replacing the 36v battery on my A2B Alva+. I’m replacing it with a new aftermarket EM3EV Super Shark battery. The picture is after i disassembled the stock battery pack and shows the stock battery electronic internals minus the old Lithium batteries. There is an on/off push button switch, a 3 pin XLR charging port and a Rosenberger magnetic connector to the bike.
This magnetic connector has the obvious positive and negative wires. But it also has a small blue and small green wire and I’m unsure what these are for. Im worried they are Important! The stock bike has 3 assist modes, a key fob, display and a throttle and I’d like to retain those functions if possible.
I’m trying to figure out how to connect the new EM3EV battery which only has positive and negative. I’m unsure if I should connect the new battery directly to the bike (discarding everything in the picture) or I should reuse some components from the picture for the sake of the mystery green and blue wires. I appreciate your help!
Option 1) discard stuff In picture, ignore blue and green wire, wire new connector to positive and negative on bike.
Option 2) reuse Rosenberger magnetic connector, ignore blue and green wires, discard rest.
Option 3) retain everything and wire the new battery to the positive/negative on the circuit board bullet connectors. I think this would mean I have two battery management systems though (old one pictured and new one in EM3EV battery)
Thank you thank you thank you!
