MitchJi
Hi,
I'm trying to build a tool to roughly compare the paramagnetism of various sands (lava dust and crushed basalt and crushed granite).
I tried using one of these magnets:
http://www.lighthound.com/Magnetic-Spacer-for-Charging-14-x-14_p_1047.html
Will the Magnetic force be proportionally stronger if I add 1 or 2 of these (same diameter, 1.5x longer), instead of the shorter magnets?:
http://www.lighthound.com/Magnetic-Spacer-for-Charging-CR2-or-14250-Battery_p_1048.html
I think its going to work better if I can get a stronger Magnetic force, at one end of the magnet. If I place 2 or 3 in "series" will I get more Magnetic force at the ends of the magnets? If so, how much (2 magnets = 2x the force?)?Magnetic Spacer for Charging 1/4" x 1/4"
Part Number LH14Mag
1/4" x 1/4" nickel plated neodymium disc magnet, poles on flat ends
Thanks!Magnetic Spacer for Charging CR2 or 14250 Battery
Part Number LHCR2Mag
1/4" x 3/8" nickel plated neodymium disc magnet, poles on flat ends. Fits on positive end of CR2 battery for charging in CR-123a size chargers.
