GGoodrum said:A "bi-drive" BMX hub? Not that there's anything wrong with that (), but what exactly is this? Are there chains on both sides?
They can be for us
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=11495&start=17
GGoodrum said:So, the 3-sprocket widget you had links for hs its own freewheel? That would open up some more options, I think. I'm curious about what this was originally intended for, do you know? What other application needs a separate FW from the one on the splined hub? Tandem maybe?
Miles said:It's just a 3 speed freewheel.... Once upon a time 3 speeds was all you got...
Miles said:The cassette type hub does indeed integrate the freewheel mech into the splined driver - a generally more robust and flexible arrangement.
Miles said:deecanio said:I didn't want to thread anything onto the eno i was thinking of just attaching the extron to the eno and then have the 15t right beside it on a freewheel cassette thread giving me two freewheels, one for the motor chain and one for the bike chain? that would give me independance no? :? :? :?
Yes, but...
How would that work with such a short thread: http://www.sheldonbrown.com/freewheels.html
Or, your planning to put a thread on the splines of a cassette driver?
If it were possible then the motor sprocket would have to be on the outside.
liveforphysics said:![]()
Maybe I'm not getting a good angle from this limited photo, but is there some reason that necked-down area couldn't be bored open wider, and splines cut into the threaded area. We will obviously no longer need the spline engagement area for the freewheel removal tool. It appears to have have enough material there to make it possible to slide on cleanly. These things are very tough to judge without holding one in your hand though.
-Luke
Miles said:liveforphysics said:![]()
-Luke
I guess it's just about possible - there wouldn't be much material left around the lock ring threads, though...
See the photo here: http://www.tartybikes.co.uk/product.php?product_id=2054&category_id=65
I'll wait to see how you get on with yours![]()
Mud, could you find links to the parts you mention, so I can get an idea about what you mean.
liveforphysics said:Thank you for the picture Miles........If you happen to have one handy, could we burden you to take a few measurements for us? 9spd spline major and minor diameter, and OD on the necked down area of the freewheel.
Luke seems to have the greatest persuasive power.... LOLdeecanio said:persuade W.I. Miles![]()
Anyone have any Mafia contacts?deecanio said:Would be awesome if W.I. made us some custom ones though - fancy trying to Persuade them Luke?
For how much longer will the small BMX freewheels be available.....? They all seem to be converting to erm... cassettes.gwhy! said:This is what we need ( well some of us anyway ) "Cassette hub converter converts any Shimano cassette hub except silent cluth and pre 1997 Dura Ace, to a fixed gear" . but longer, with a step down threaded portion and the outer edge to accomodate the bmx style small freewheels. wonder how easy it would be to make something like this..... matt :wink:
Miles said:For how much longer will the small BMX freewheels be available.....? They all seem to be converting to erm... cassettes.gwhy! said:This is what we need ( well some of us anyway ) "Cassette hub converter converts any Shimano cassette hub except silent cluth and pre 1997 Dura Ace, to a fixed gear" . but longer, with a step down threaded portion and the outer edge to accomodate the bmx style small freewheels. wonder how easy it would be to make something like this..... matt :wink:
I agree, it's a good idea, though... :wink:
