Snakes butt
Ive got a Benelli Tagete And the controller is playing up, I want to get a new one the motor is a bafang mm g33.350 and I cant find one, does anyone know which model has suprceeded it and which controller will fit?
I searched on "Benelli Tagete controller is playing up" and it only pointed to this thread. Maybe you're using a different search engine or criteria. I added "intermittently" and still nothing.Controller becaue thats what the web has thrown up & its 4 years old.
Got it. Ya "playing up" doesn't mean much in ebike troubleshooting. Maybe amberwolf will be able to help out. He has a way of patiently asking for usable information needed to resolve issues.I cant remember what I typed into google now but it wasnt "Benelli Tagete controller is playing up" it was sorthing like "bafang mm g33.350 working itermittently" but not that.
He was kind enough to be the first to respond to your post.All I get when I type 'amberwolf' into Google is a Tiktok Video! can I have the address please. PM me if you need.
All works apart from the motor which is operating intermittently it will try to pull and its not making the noise it normally does
Thanks for that bread crumb trail. The OPs unit looks a lot like this one, except for the serial number.Regarding replacement parts, I am not sure which system yours is, but when googling "bafang mm g33.350" the MAX and the M400 systems come up a fair bit. Does the unit at the pedal area of your bike look *exactly* like any of the ones in this search?
or this one?
You can just contact Bafang and provide the pic of your controller, since it doesn't appear there are a lot of folks jumping in that have the same bike. HomeStill the same even after being put back together. So its back to the original question does anyone know of a mm g33.350 controller? or which model has suprceeded it and which controller will fit it?
If you don't have a throttle, then torque sensor is the only thing that tells the controller to provide assistance, based on/proportional to the amount of pressure you apply to the pedals. If the sensor is failing or if there are poor solder connection, etc., then it will affect to signal to the controller.Do you ever ride in wet conditions? No dry, dusty.
Will the bike still work without the torque sensor, or if its disconnected? How do you test evrything?
