convert positive ground negative V PSU to regular?
john61ct
1 TW
How should I install a rackmount 3kW -48V telecom power supply - note the minus - to charge a regular (no minus) 48V battery system from mains?
The enclosure chassis can be floated from the internal rectifiers, and
when used on a vehicle or boat, there is no Earth Ground, the whole system on both input and output sides only have Chassis Common / Reference available.
The eBay seller says it can be done, but says for liability reasons doesn't want to explain how.
If you have a negative voltage supply that you need to use to power a two-wire-input positive voltage device, you simply use the negative voltage output line of the PSU as the negative (ground) line of the device, and the ground output line of the PSU as the positive line of the device.
This is simply because any voltage is only positive or negative with reference to itself. As long as the two devices being connected are only connected via the two DC voltage wires, and nothing else between them makes electrical contact, neither device has any way to "know" that the other one is the "wrong" polarity, as long as it is hooked up correctly with reference to which wire is "more positive" than the other.
If the devices share any other electrical connections, this doesn't work, and may result in destruction, fire, cats and dogs living together, ectoplasmic streams in your sewer system, etc.
However, a couple of points:
A "48v" battery is unlikely to be chargeable from an actual 48v source. It usually requires around 55v for a 13s LiIon pack, normally called "48v". For a LiFePO4 pack, it would take around 58v (normally a 16s pack for "48v"). So it depends on what chemistry and how many series cells your pack is, for exactly how much voltage is needed to charge it.
A typical power supply, which probably includes this telecom supply, is not designed to limit current, either at all, or in a way that's usable as a battery charger. Many of them will simply shutdown when used this way, or a fuse (or component used as a fuse) on the output will blow. Some poorly designed PSUs will destroy themselves attempting to supply the current asked.
Unless the PSU is designed with a constant-current type of current limiting supply, where it lowers it's output voltage to keep the current down to it's maximum limit, it generally is not usable as a battery charger.
There's a lot of discussions on ES about using various PSUs as chargers, many (but not all) of the threads include the word Meanwell somewhere in them, to help you find them.
Thanks **so** much amberwolf! and happy Christmas (to all!)if you're so inclined.
Looking for corroboration from others that this
is 100% true and safe
before I pull a $500 trigger on this top notch world-class PSU, brand new NOS
or please add appropriate caveats.
7kva output, adjustable 44-58Vdc output, world power inputs, from 90-280Vac, 50/60Hz, very compact and quiet. Each rectifier module can be independently fed, e.g. 5x household US 10A circuits to get to 5kva, or multiple Honda inverter gensets.
The included control module on its own, often sells for higher than that $500
So, y'all think sounds like a good deal?
56.5V is my 100% Full cutoff for 16S LFP at high amps.
I will limit current manually, depending on size of LFP bank, certainly not exceeding .3C unless in a real hurry for some reason, very rarely, maybe up to 1C sometimes. And of course only if the upstream supply is big enough.
Plus of course fuses upstream appropriate for the source, and downstream sized for the target bank.
<snip>
How will you do that?
Well it's pretty essential functionality in battery charging innit?
As just stated, this modular telecom rectifier includes the sophisticated control unit option, so CL functionality is built in.
Plus, all my AC-DC and DCDC charge regulators, even my alternator VRs, allow de-rating amps, both to accommodate current limitations upstream - small gennies, 10A 110 mains circuits - and in order to protect target battery banks from harmful levels of overcurrent.
Can't imagine making do without CL actually.
Yes, it is, which is why I asked about it. But manual limiting is not the normal way of achieving that (automatic limiting is), because it's kind of a PITA to have to sit there thru the whole charge cycle monitoring current and manually changing the whole time to keep it where you want it.
Ah; I must have missed where it said it did current limiting on it's own. (I still don't see where it is stated in the posts above).
But that is different from manual current limiting, which means doing it yourself via some external control, and that's why I was asking, to find out how you were going to modify the equipment to let you do that.
I only need to set a maximum value, not to be exceeded, e.g. 400AH bank @130A charger output, if 12V then ~1800W.
Which is 38A output from the PSU @48V, no problem there.
But if upstream 110Vac is only a single 10A circuit, or 15A with other loads running, will futher derate - either at the PSU itself, or within the downstream DC-DC charger's controls.
I don't sit there and adjust during normal charge cycles.
With lead the amps will trail down until .005C is reached, with LFP I don't normally Absorb at all, just charge to 3.45Vpc and stop.
Of course with testing / maintenance protocols, things get more precise.
Next question, since true Earth Ground is not available.
To prevent risk of shock from the flipping polarity
Should I
A. insulate / further enclose the outer enclosure chassis, put big DANGER safety stickers around it, wear rubber gloves etc, or
B. isolate the case from the actual rectifier modules?
I plan to not allow anything to short with it, in either case.
The negative returns on ultimate load devices and battery banks are tied to the "Vehicle Common Reference" pseudo-ground, chassis frame, engine block etc.
Anytime you can design a system to electrically isolate the parts that you can touch from the insides, I'd recommend doing that. Some systems are already done this way, but some of them built to be inside something else don't bother, because the other casing it's supposed to be in would keep people safe from it, and it costs more to insulate and isolate everything, and complicates thermal management at least a little, too.
Often enough, you can't fully insulate an exterior casing of a PSU that's meant to go inside something else (which would've provided cooling or whatever), becuase of heat-shedding problems, since typically anythign that is electrically isolative is also thermally insulative to at least some degree, and/or blocks airflow necessary to convection-cool something important.
I definitely don't recommend that.
That means the entire thing is electrified, and just waiting for a positive to rub thru the insulation and short to it. Or be pinched by it in a crash, and cause a short. (if the fuse or breaker doesn't pop, then a fire could result).
Iv'e seen this happen to various vehicles with 12v wiring, and in one case the battery exploded, ripping the hood off the car and flipping it up quite far in the air to land on another car in the parking lot, because someone trying to help jumpstart the car accidentally pushed the jumper cable clamp for positive against the car frame, where it sparked, welded, and was unremovable as the cables began to burn, and then the battery overheated, boiled, and bang. Since the battery terminal is where the jumper was clamped, the fuses on the system could do nothing to protect it because they were all downstream of that point. :(
I don't really want to think about the fire a large lithium pack could cause if something like that happened. Hopefully the design of the rest of the wiring harness would be able to prevent it...but it's safer not to use the frame for any electrical connections.
Also, it presents an electric shock hazard for anyone working on it. ON my CrazyBike2 (admittedly much more "science-project" than "engineering-award" quality :lol: ), I used the frame for ground, and ground was common between 12v lighting system and 52v traction system. I had a circuit breaker mounted on the frame just forward of the seat, that switched the positive of the traction system. Rainy day, and water conducted via dust/etc from the breaker connections to the frame, causing odd behavior and then tripping the breaker. Another time, I was holding the frame and moving the bike, and one hand was on a wiring harness that had an invisible insulation defect, and my sweaty hands conducted very well from that thru my body to the frame ground. Not much fun. If I had a higher voltage traction pack it's possible I wouldn't be posting this.
SB Cruiser trike early version had frame ground, and a positive 12v system wire direct from the battery pinched between a plastic case and the frame, shorting the battery (but not popping the breaker!) and setting fire to the wiring harness all the way back to the battery terminals. Thankfully I was able to stop and get the case open (which allowed the hot smoke to burst into flame in my face) and get the wires off the battery, before the battery itself could reach fire point.
I don't use frame grounds anymore, for anything.
If all electrical is kept completely isolated from all chassis, etc., it's safer.
I know cars are still built this way...and most of them don't catch fire from it...but it's still not as safe as not doing it, and some do still fail catastrophically from it. THe main reason it's still done is that using the frame means only half the wiring has to be done for the lighting system, since the other half is the frame. Cheaper in materials and labor. If the cost was teh same, I doubt they'd still do it.
Thanks so much for that in-depth reply.
I did not mean to imply I was using Vehicle Common as a Return path for negative side between the DC banks and loads. I never do that myself, always wire the full round trip back to the power source.
Crimpers costing thousands so gastight milspec terminations, UL1426 105c tinned "boat cable" only, Ancor fittings, the lot.
However when buying a boat or vehicle, the core infrastructure is already in place, and best IMO left as is.
In any case, it seems the "isolate rectifier modules from the chassis" is the primary approach.
I will also strive to ensure the unit as a whole is shielded / protected from contact, within its ventilation needs.
I have come across a more normal negative-return 48V PSU unit going very cheap, so will now turn my attention to researching that for the sake of KISS.
Thanks to all for helping me climb this steep electrickery learning curve wrt positive-return DC and AC grounding.
OK, have been convinced to abandon adapting from the "positive ground" -48V telecom standard to "regular" negative common / reference.
Looking for feedback on / help with TDK-Lambda PFE1000F 48V PSU (actually Densei)
Specifically on how to parallel three units, could not find the Appnote mentioned in the spec sheet
