Converting a samurai
hillslayer@
California
I have a geared down rock crawler want to convert to electric as easy as possible. Should just be able to pull the motor and hook something directly to the transmission. Any suggestions on what motor would be best, not worried about going fast at all since it's has a massive gear reduction was thinking about not needing a super powerful motor.
...very cool car to convert.. following!
If you put your conditions, gearing, wheelsize, etc into the ebikes.ca motor simulator, it'll help you figure out how much power you need to do what you want. you can also use the info to figure out the battery capacity and capability you'll need.
Netgain hyper 9 conversion kits.
Low voltage/high current air cooled motors.
Motor weight 130lbs for largest motor
Can be had with adapter for various manual transmissions.
Evwest.com is where I seen this info.
They also have other kits.
