Because that requires high motor speeds to function and stops working when the bike stops moving. I suggest you read the rest of this thread to get an understanding of the kind of requirements that have driven this modification.burningwings said:Since the motor is moving why not bore holes and put fan blades on the rotor as John did ? Most electric motors have built in fan blades way more simple solution.
I would use epoxy. If it fails you can always try again with screws where as if you try screws first you will be left with holes.Offroader said:I have to mount the air duct and cover the large holes with plastic. Is epoxy the best way to do this?<br abp="682"><br abp="683">The only other alternative I can think is to tap small holes and use tiny screws to hold everything together.
Cheers
