heyitsaustin123
🧲 New user
- Joined
- Oct 5, 2019
- Messages
- 1
Hey All,
I am in the planning stages of my first build, I've read Micah Toll's book, and I'm getting ready to pull the trigger on some purchases so I'm looking for some oversight from you more knowledgeable E-bikers before I shoot myself in the foot. Just a little background, I plan for this to be my everyday commuter (when the weather is cooperating) in addition to my around town grocery getter etc. My commute is
each way according to Google and I live in a fairly hilly place.
Battery
I'll start off with the most controversial... the battery. I've settled on building a 13s5p 18650 pack housed within a 65-cell Hailong case. It seems these are all about the same from the various Alibaba vendors but this one has the most orders. Originally I was going to get the version with nickel strips and USB because I like the custom cut strips but the vendor told me they are nickel plated steel so now I am thinking otherwise. I live in a fairly dry climate (Colorado Front Range) so I'm not too worried about corrosion but more so the extra resistance. Is this a reasonable worry? The pre-cut seems much cleaner than cutting strips by hand. Could I tack on an extra strip of Ni to beef up series connections? As for USB, I plan to use a 48V to 12V regulator to power lights, phones, laptops etc. anyway so not much of an issue.
As for cells, I've settled on the Sanyo NCR18650GA but haven't decided if I am going to purchase from Tumich or QueenBattery. Tumich is a bit cheaper but I'm worried about taxes/import fees. I picked this cell as I love the high capacity, my current draw (4.17A) is well within the 10A it is rated for, and I shouldn't be putting deep cycles on it all too often as my commute is short so should still see pretty good cell life (I think?). As this is the most expensive and crucial component of the build please let me know what you think about this cell! I know this pack is probably a little overkill for such a short commute but I like the added buffer and I will be pushing it time to time while exploring on the weekends. Also, I plan on using the XT60 as my connector.
I plan on picking up one of these Arduino Spot Welders from Malectrics
BMS
This one gets its' own section as I am particularly worried about this destroying my pack. I am thinking about one of these ANT Smart Bluetooth BMSs, the 7S to 16S 100A model without the LCD should be sufficient. I don't think I'll need an LCD if I can get all the data on my phone. I should be able to set a cutoff charging voltage to 4.1V allowing me to use any 'ole 48V charger.
Motor/Controller
As for the motor/controller I am planning on going with a cheap EBay kit like this Voilamart 48V 1000W kit. I figure, the motor will be pretty good and if the controller ends up sucking, I'll just get a new one eventually. AFAIK these Ebay kit motors are all pretty similar.
Yet to figure out/Questions
Charger- I assume I can use any ole 48V charger with the BMS cutoff set correctly. I was thinking something like slow and fanless like this 48V Dolphin Charger from Luna. Maybe there's an even cheaper alternative so I can have one at work/home. If I really want to charge fast, I'll use one of our beefy adjustable power supplies at work and do it by hand.
Spot Welder- I plan on picking up one of these Arduino Spot Welders from Malectrics. Seems pretty sweet but if anyone has anything cheaper/better lmk. Having to lug a car battery is less than ideal but not enough to go for the lipo one. I have access to 120/240V 208/230V at work if needed. I'm splitting this with a co-worker who is also building a pack.
Lights/Accessories- Haven't picked any lights out yet but plan on headlight, tail light, and maybe signals. I was thinking of running these off the 12V regulator as 12V accessories should be cheaper/more common but if you have any other suggestions let me know. May also get a set of 12V heated grips. Eventually I plan on buying another battery receiver to use the battery off-bike for powering an inverter, charging phones/laptops, heated blanket etc. on climbing trips.
Bike- I'm waiting on getting my battery case to go bike shopping as I want to make sure it will fit. Will likely go with a cheap steel-framed mountain bike off Craigslist which should be pretty easy to find in Colorado. Can disc brakes be used with these kits?
Final Purchase List
Hailong case
65x Sanyo NCR18650GA
each way according to Google and I live in a fairly hilly place.Battery
BMS
Motor/Controller
Final Purchase List
Hailong case
