Range Anxiety
Today I answered the age old question - can I make the round trip to work without charging.
You see, I forgot to charge last night...
I've been using about 8-9 am hours going home, and about 12-13 amp hours going to work. Which is a round trip total of 20-22 amp hours out of 20.
Going home last night I used about 8 amp hours. So in theory I had about 12 amp hours left, but that has never been verified, and even the calibration of my CA has never been accurately tested.
This morning as I picked up my helmet I realized that I forgot to charge the bike last night.
So the question was - take the suv (can't do that as it is going in the shop today), take another ebike (could do that, but no rack on the recumbent, and the mountain bike is buried behind other stuff), or hyper-mile and see what I could do...
So I left the motor off as I went down my street (slight downhill), and switched into speed I. All the way to work I kept the speed down to about 15-17, pedaled most of the time, and used regen when I could to keep from wasting energy on downhill speeds above 15 mph.
I arrived at work with these CA stats:
26.2 miles (total round trip)
16.6 amp hours (of 20 rated, never verified)
1175 watt hours
44.0 watt hours per mile
2.1% regen
17.1 amp hours forward
0.35 ah regen
-37 amps min (regen)
77 amps max
18.9 mph average (my home bound trip was not slow, so this skewed the average higher)
1 hour 23 min (for both trips)
947 miles on the odometer (two more commute days to 1,000 miles)
66.7 volts at end after a few minutes rest (LVC is about 63 volts)
The charger is on now, so we'll get another reading on amp hours from that soon. The balance looks good after an hour of charging.
For all you folks with light ebikes this may seem like poor efficiency, but remember this is a 110 pound ebike with full suspension and fat moped tires, it takes a bit more energy to move it.
As we already know, slowing down helps efficiency a LOT. Pedaling a lot helps some too, but slowing down is even more helpful.
This is one case where the Cycle Analyst allowed me to make this trip safely and gave me the information so that I could plan and know what I needed to do, and helped protect my batteries. Folks often ask if the CA is worth the cost. My answer is, if the CA saves your battery pack ONCE, it has paid for itself several times over. Riding without a CA is like driving with no gas gauge, speedometer or odometer. In other words, like driving with no instruments. There are other ways to get speed, voltage, current and wattage, but integrated amp hours over multiple on-off cycles is not so common.
This is one time a powerful charger at home would have been useful. I could have taken 30 minutes and put 6 amp hours back with my 12 amp bulk charging system that I use at work. I could even charge as part of my morning ritual instead of charging the night before. Just might have to get another set of those LED power supplies soon...
I'll sleep well tonite.
