kudos
I was riding along under power just now but it has been bugging me for a while that my speed doesn't display correctly on my APM because I have big hookworm tires.
So I pulled over, went into the APM settings and changed the wheel size. Setting it as 27 or 29 seemed to give far to high a reading and even 25 was too high so just to see what value it would give I set it to 20.
I then turned the throttle and no power to the motor. The APM still shows PASS, voltage, speed, ebrake etc but I get no power.
Huh?
I came home swapped over to another controller and battery and everything is fine. So throttle and motor is fine.
I don't know what on earth the problem could be. All i did was change wheel size setting. Obviously I changed the wheel size setting back to what it was but still nothing.
I've tried unplugging the APM. But I seem to remember that the controller remembers how you set it with the APM.
I've checked LVC etc. Checked it's in speed not assist mode.
I can't find any way of re-setting the APM or controller anywhere?
Help?
Kudos
Huh?
Help?
Kudos
