I rode motorcycles for about thirty years and also bicycle commuted, till I couldn't manage either anymore. I got so weak that I could barely walk the forty feet to the mailbox, on a level driveway, without falling over/passing out. Dialysis (and the other related stuff) ain't fun and is only partially effective - varies per individual. I've had a used kidney sewn in (twice) and am working on reducing tonnage - 90 lbs down so far, and another 70-90 lbs would be better.
The current Photon-powered bike is a bit of a specialty-purpose build (
described here) and I'm awaiting some light wiring parts for it, so it's up on the repair stand right now. I've only got a handful of short rides on it so far, but have some torque-sense only, 20-30mile trail rides in mind to test it out properly. The CYC throttle has a clamshell design, and I intend to remove it for these rides - promise!
I believe in choosing the components for the package and ride intent - in this case a smaller outline (20" wheels), lighter weight bike to be ridden on mostly easier grade rails-to-trails terrain. The desired speeds are 10-15 mph torque-pedal-assisted and low to mid 20s mph sustained throttle, with peaks in the high twenties, if having to deal with short stretches of dense traffic. 30 mph is about the top speed this bike loaded down with gear, seems to be happiest with stability-wise, and that's more than fast enough for the intent.
Range, even lightly motor-assisted, is also part of the intent, and dropping the speeds doesn't hurt in that regard - especially if I have to push the battery to fumes. Out to 100 miles max over two days, I hope - 17-21AH battery capacity is my best initial guess.
Sound-wise, I've had a chance to listen to it, riding throttle only in the twenties, and with enough tailwind to reduce wind noise. I'd say the decibel level is between a stock BBS02 and a PEEK-geared, well broken in BBSHD (which is, for me, a VERY quiet motor). The sound quality is less gear-mesh-ish and more white-noise-ish.
The ass/saddle friendship is not a problem for the time & distance - the leg output is. But, I've got a few years to work on it.
I've got another CYC Photon on order, again to replace an existing BBS02 - this time on a loaner bike build for seniors (
described here).
These seniors, in their sixties-seventies who haven't balanced a bicycle since they were a kid and haven't sat on a saddle in that long, have a hard enough time getting going - beyond trying to understand the complicated cadence power levels. I want to mellow down the power delivery and peaks, set the bike on level one or two, and send them on their way (hopefully, having fun, on a safe paved trail, with no walkers they can hit). Via the app, I can give them more oomph, should they gain confidence and ability. But no throttle, at least not initially.
I've got a lot of e-bike curious old-timers, a few maybes, a few I'll try it, but only one street-comfortable street-safe rider so far (BBS02 motor and MSF-trained). Given comfort levels and the right roads, I hope to convert a few more, at least. Keep the car, just use it less, when possible.
