Atak_Snajpera
- Joined
- Jul 21, 2022
- Messages
- 335
Can you record output from the app? I'm curious how fast those temps raise to warning levels.
It is what it is. In this case, small and built to a price point.I was over 60C motor temp before I even started the climb. This ride was a shit-show. Never used the throttle, and PAS was limited to 700W. Unimpressed.
I'd much rather haul 10kg of motor I never have to worry about than 5kg of motor that makes me monitor it to prevent overheating.
I think it would be worth your while to screen record the entire ride and pass that to CYC for interpretation (though in my experience there's plenty of people who will offer an opinion here for free). You never know, maybe they will identify that your motor is an anomaly. The problem with a static screenshot is that I think your temp is way too high for the power indicated but I can't see what happened previously. Running continuously at 600W I wouldn't even break 60C, especially at that cadence where it should be fairly efficient.Well, the photon still suffered runaway temps and down-throttled.
Here's my power settings:
and here's my screengrab during my climb:
It is hard capture the throttled power levels because it doesn't stay constant... it bounces around while trying to keep from melting, but the lowest that the motor down-throttled to was 495W.
This is a 500W nominal motor.
Next month it could probably even open a discussion with CYC, negotiate a replacement and organise shipping. The growth in this area is way past exponential.I didn't know that chatgpt is so advanced that IT can built csv from video. In the past i was using ocr tools to convert numbers from video to text. I still have a script which uses ffmpeg, avisynth script and teseract. GitHub - tesseract-ocr/tesseract: Tesseract Open Source OCR Engine (main repository)
Are you using the throttle? My understanding is the throttle is Not limited by the mode settings. Which means your throttling in unrestricted mode? But I could be way off baseAnd I need to comment on the shitty thermal/power management system of the CYC Photon. It is really hard to maintain steady power output from your legs and cadence with the power output of the motor jumping around in a spasm. I would almost rather just limit the damn thing to 250W just to avoid that dance while riding.
And yeah, 4 more pounds will get you a capable motor that won't spaz on you when you need it. Worth it.
This is Photon:There is Toseven DM02 4kg
I still can't figure out why this chinese motor is more expensive than for example german motorsSmall size gives great ground clearance. It barely protrudes past the 34T chainring. For some people, that is far more important than being able to run at 1500W.
I am not using throttle, but regardless I have throttle limited to 700w as well. I am treating the motor with the same delicate care as a newborn baby.Are you using the throttle? My understanding is the throttle is Not limited by the mode settings. Which means your throttling in unrestricted mode? But I could be way off base
All these motors have their own characteristics and limitations. Pick your poison. But if your selection doesn't meet your expectations that doesn't mean it is terrible or not perfectly suitable for many others.
Yeah! Some systems are perfectly suitable for people who enjoy their stuff broken and undependable. Don't judge.
"Don't judge." Really Chalo? Do you own one of these drives? Have you ever worked on one? Have you even ridden a bike equipped with one?Yeah! Some systems are perfectly suitable for people who enjoy their stuff broken and undependable. Don't judge.
There's a percentage of ALL of these motor systems that is either initially defective or fails - even the 10kg of whatever brand/type your motor system is.I'd much rather haul 10kg of motor I never have to worry about than 5kg of motor that makes me monitor it to prevent overheating.
My two Photon motors have held up fine and work very well, as have as my Alfine hubs driven by mid drive motors. Both ridden on hot summer days, for many miles.
I've not got a similar climb near me, and believe that it would take riding along side @nervagon to appropriately match all of the conditions. Sorry no, I can't afford to relocate at this timeI (a?) user with a known good motor should reproduce what nervagon is doing - if they can, and the motor doesn't overheat, then we could say with pretty good certainty that nervagon's motor is faulty. Otherwise we're arguing theoreticals without proper information.
Not directly comparable, but I've run both of my Photons as fast as they'll pull the bikes (unlimited 2kw setting, and just past 30mph), and have never experienced overtemp power pullbacks that severe. I ride relatively upright, and at the time weighed mid-350s. I have to work at getting the motors to roll off power at all.It was a 1 mile climb up a 10% grade at 8mph, and the motor hit 89.9C degrees and throttled down to 350W on a 75F mild day.
I agree, but based on what little riding experience I can compare I suspect your motor has a problem and it needs to be stuffed up Electrify Bike's collective butts.And long 10% climbs is precisely why you would choose a mid drive over a hub motor. If a mid drive can't handle that... well, the motor sucks IMO.
