I'm having a hell of a time interpreting how the advanced settings work. I really wish this manual gave some examples of how doing X,Y, and Z will give you such-and-such kind of outcome.
I'm assuming that a very simple way to extend the range I can ride is by reducing the Max Throttle setting, but the last part of the explanation needs further explaining:
"8.15 Max Throttle
This value puts a maximum cap on the throttle output signal. It can be
useful to simulate a lower speed motor by simply clamping the throttle
signal to a value between 0 to 5V. Be aware that the majority of hall
effect throttles only operate from 1V to 4V, and so the desired setting to
reduce the speed would fall in this range less the diode voltage drop."
"...less the diode voltage drop." - Huh? The way I understand the above paragraph: the throttle has a practical range of 1 to 4 volts, 1 being almost a standstill, 4 being the equivalent of full-throttle. So, there is a practical range of 3 volts. If I set this to 2.5v, will I be running at half throttle?
Also, anyone know the proper setting for the "Set Rshunt" for a 36v Bafang motor with a 36/48v 20 amp Infineon controller? I wonder if I have this set wrong (it's at 5), since the most amps I'm able to draw is around 13.
Thanks for any light you guys can shed on this. I really want to understand how the CA works...
"8.15 Max Throttle
