chuyskywalker
In summary, everything appears to be connected and I can see spin/rpm, but no motor spin with the PAS.
Not really quite sure where to go from here. What little tidbit of info have I missed from the manual about setup that would make the motor spin when the PAS spins? Is there a setting somewhere that might be disabling this? Do I have the ca throttle in/out setup messing things up, maybe? I just don't know :}
- I've got a Mini PAS from Grin plugged into the CA
- The CA is wired down to a Phase Runner
- Everything is on the latest versions of software
- Throttle works
- Spinning the PAS doesn't cause the motor to kick in
- Display shows that spinning the PAS creates the little RPM LCD block (right next to the throttle/ebrake icon)
- The ebrake icon is not engaged unless I'm on the brakes
- In the secondary screen, I can see the RPMs reading when I spin the PAS
- Configured for "Basic Power" with 500watts
