teklektik said:Did you go through the Guide setup procedure again for normal instead of legacy mode?
You need to start anew when you change modes...
teklektik said:You have skipped something - wrong throttle mode, bad throttle out values, etc.
You should see your throttle out voltages appearing on the Diagnostic Screen and the same voltages at the throttle connector. If the OUT field is not changing then you are definitely misconfigured.
Use the CA Settings Utility to extract your settings (like this) to a hex file and post it up here.
you got a DD hub? so yes. you should get the speed signal from the controller. the yellow wire is the speed signal wire (pin5). where is it connected inside the controller? there should be a solder pad named "SL1" or it could be one of the hall signals if SL1 is not available. post a photo of your controller with the appropriate solder pads if unsure. take a look at page#57 in the manual which explains connection inside the CA. page#58 explains the connection inside the controller.liamcaff said:My next problem is still no speed feedback to the cycle analyst, except when I use the magnet and sensor from the CA-DP... I'm sure I should be getting speed directly from the hall sensors no?
izeman said:you got a DD hub? so yes. you should get the speed signal from the controller. the yellow wire is the speed signal wire (pin5). where is it connected inside the controller? there should be a solder pad named "SL1" or it could be one of the hall signals if SL1 is not available. post a photo of your controller with the appropriate solder pads if unsure. take a look at page#57 in the manual which explains connection inside the CA. page#58 explains the connection inside the controller.
we'll get all your problems sorted
NeilP said:The yellow wire you are referring to above the red, is one of the yellows from the controller hall sensor outputs, will be marked SA on the back of the board.
on these boards i have here (Lyen 6 FET ) the other yellow is green and in to a hole labelled HE on the reverse.
There may also be a yellow, to a diode to EBS-, the brake line.
According to this post in this thread, SL1 is as I suspected the throttle line from the CA-DP plug.
Please stop.liamcaff said:Just want to be clear:
Controller is: 12FET Lyen Modder Controller
Cycle Analyst V3-DPS (not DP as previously stated)
teklektik said:Please stop.
This is going in the wrong direction entirely. There is no reason to believe the controller is defective and wired improperly or to further investigate the hall connection. You have a controller with a CA-DP connector. It works. Done.
Put the controller back together as it was and make sure it still works as before you began disassembling things.
You have a CA-DPS. This requires a minor modification inside the CA -- NOT inside the controller.
Please do as it says in "Appendix B. Add/Remove Wheel Speed Pickup Sensor" of the Guide.
Don't forget to reset Spd->#Poles appropriately for your motor.
NeilP said:That is what comes from trying to read posts on the iPhone.
I had no idea about the initial problem. I was merely warning against this talk of (to me) the mythical SL1 connection.
I had not read back far enough up the thread.
Swapping a DP Stand Alone to controller signal for speed is, as you have found, very easy.
Sorry I did not pick up that that was the issue.
NeilP said:...Sorry I did not pick up that that was the issue.
+1rscamp said:No shame in trying to help!NeilP said:...Sorry I did not pick up that that was the issue.
Ya - this wonky PCB label has come up more than once before in this thread. The UUG PCB labels are from a Grin document about the Grinfinion controller and apparently the Keywin variety of Infineon board differs in this respect. This is particularly unfortunate since the UUG Appendix is only to explain CA-DP interface function and not how to wire it. The pad labels have turned out to be misleading and a handicap.NeilP said:If what I read is correct ( in the UUG?) then the CA-DP goes to a SL1 pad. Have 3 dead CAV3 compatible Lyen controller boards here and not seen this SL1 yet.
SLA and SL, but no SL1, so take care you get the correct pad.
liamcaff said:.
Will start into getting Regen braking working next along with 3-speed switch... Then I should be good to go!
liamcaff said:. and try not to hog the CA thread!
