i'm just about to give up. i just can't get a satisfying riding experience with a smooth throttle response and steady power output.
as you may know, it's a 2.2kw middrive driving the wheel through the rear gear cassette. so power (torque) demand varies a lot depending on the gear set. i have a 3 way switch installed (like in the CA manual, 3 resistors that set POWER limit to three defined levels) so i can switch down power easily.
example: i ride up a hill. throttle is somewhere in the middle position, and throttle in/out voltage doesn't change - checked at the '#11 diagnostic screen'. still the amps jump around like crazy. from 12a up to 20a in a fraction of a second. if i apply WOT then it accelerates quite ok (still not smooth) but starts cutting/applying power when full speed is reached.
i tried adjusting only ONE value which is Pgain. i trying from 100 (undriveable) to 3 (quite ok, but still not smooth, and for the cost of super slow power application).
if i remove ALL limiting it rides quite nice. but this totally make all PRESETS and AUX SWITCH useless.
i made a screenshot of my settings. maybe i follow a totally wrong path and try adjusting the wrong parameters. i just can think that i'm the only one with a mid drive that has is not able to adjust the settings to be satisfying.
these are my settings:
any help is really appreciated - just to keep me from banging my head to the wall
