Thanks for the post.givitago said:Thought I'd write a quick post on the off chance others had the same question as I did.
I have a cell_man mac and 30 amp controller and I was wondering if the cruise control would still work properly when the CA is used with throttle mapping/limitting.
Turns out it does for the most part as does the three speed switch wrt the controller functionality. One slight issue is that using the throttle to disconnect the cruise is now unreliable so either the cruise button or e-brakes (wired directly to the controller) are needed.
Looking ahead a bit:
- Justin has proposed a CA-to-controller ebrake-pass-thru solution in this post in the context of providing regen support. However, it seems this should be equally effective in providing controller cruise control disengagement on ebraking.
- Justin also has described a cruise control feature for the CA in this post that could serve as a substitute for controller cruise. Software-only means it may appear sooner than the hardware do-hicky above...
A good strategy for the near term... :wink:givitago said:Now off to play with some reed switches for ebrakes ...
