Yep. Nope.RC_guy said:I dont have a cable. I would need the http://www.ebikes.ca/shop/ebike-parts/ca-accessories/cables/ca-usb.html
Right??
Isnt that just a standard USB and standard 3.5 stereo plug?
Please download the Unofficial User Guide from here.chucho said:I am trying to found out what ca i need but reading all this post from the mobile is killing me :? And i could not find the answer yet... Sorry for asking as it has to be an easy one :|
I want to use a CA v3 with 24s lipo and another with 32s and about 45A. Do i need any extra or special CA to use this big voltage?!
teklektik said:Please download the Unofficial User Guide from here.chucho said:I am trying to found out what ca i need but reading all this post from the mobile is killing me :? And i could not find the answer yet... Sorry for asking as it has to be an easy one :|
Take a look at sections
The short form: The CA can operate on up to 150v battery supply, however, it's ability to supply power to attached devices (throttle, etc) diminishes as battery voltage increases. At very high voltages you will need to either:
- 5.8 High Voltage Vehicle Support and
- 5.9 Cycle Analyst as a Power Source
So - the V3 will do it - see the Guide to get a clearer view of the options.
- power your throttle or other devices from the controller (use the existing controller throttle +5v connection) or
- run the CA from a lower voltage (eg 12v) DC/DC converter so its ability to supply external devices will be increased and throttle, etc can be run directly from the CA.
We see from the video that the CA ThrottleIn measurements look like this:RC_guy said:Here it goes:
ThrIn > Min Input = .79 - Max Input = 4.27 - Fault Volt = 4.49
PLim > Max Current = 45 amps - AGain = 80 - Max Power 2200 W - WGain = 50
Okay - this is odd and shouldn't be happening - although it seems harmless in this case. Post back if the behavior persists after power cycling the CA with the 'good' settings in place. If it does, Justin will need to pursue this in the firmware. Thanks for the heads-up!RC_guy said:now while I am in the setup my wheel spins slightly???
Well - jerky starts aren't desirable but they can be 'normal' for a higher torque rig (eg MAC) that needs a little tuning.RC_guy said:I had to turn down the power gain to 30 to remove the jerkiness. Is this normal?
One thing I would like to tweek is that I find it difficult to give just a little bit of throttle. Even if I apply only a tiny bit, it gives about 15 amps. Once I get going then it will decrease and it is easier to modulate but, as soon as I get back on the throttle, it still wants to give more than I want.
There are a few things in play here that can contribute to jerky starts:RC_guy said:Up Rate = 21 V/s
Down Rate = 50.1V/s
Fast Rate = 24V/s
Fast Thrsh = 3 Amps
AGain = 80
Actually, yes. Changing the throttle curve is quite simple to do with a few resistors if you have a resistive throttle like a Magura. The procedure is described in this post. I never got any feedback on this and so didn't include it in the Guide as perhaps being a little too tweaky for the average user in spite of the simple construction.RC_guy said:Is there a way to change the throttle curve?
Yep gave that a try too. Before I did that I had no change on the CA screen. After swapping I got the PC CONNECTION message.nieles said:try swapping the tx/rx. the connction should be rx -> tx and tx->rx
Please see p40 of the Guide.hjns said:My question, please help me identify which wires Thun side are to be connected with the wires to the elongation cable.
