teklektik said:Wrong chemistry. This effect can be seen in the SOC graphs in the Guide.
You mean, I must select other BATTERY TYPE in tge setup menu??
???? There is no 'BATTERY TYPE' parameter. There is Batt->Chemistry.ebike11 said:You mean, I must select other BATTERY TYPE in tge setup menu??
teklektik said:???? There is no 'BATTERY TYPE' parameter. There is Batt->Chemistry.ebike11 said:You mean, I must select other BATTERY TYPE in tge setup menu??
Maybe I misunderstood - I thought you meant the SOC Gas Gauge display had 66% pixels.... there is no actual percentage display having to do with the battery.
Did you mean the Gas Gauge or are you talking about an actual "66%" displayed somewhere? If you are talking about an actual "66%", where are you seeing this?
yes that's it....I don't know about the kind of signal input the controller need, I will test it, but the switch doesn't look different from a normal 3 position switch, I think the controller is a modified trike/quad one but has some logic for the autoshift while in Auto position.justin_le said:Just to make sure I understand you right, you want a signal that basically reverses the motor direction of a 2-speed retro-direct motor transmission based on certain CA parameters? What is the actual nature of the input signal on the reversable controller that you are running in these systems, is it a simple 0-5V or 0-3.3V digital logic input?
That would be cool, but, I understand, more difficult than what I supposed...The kick-shift idea is funny!!justin_le said:Indeed you got me there There aren't any 'spare'' input/output ports on the CA3, so to do this would require re-purposing one of the existing signal lines to be an output instead of an input, and the only one really available for this would be the "D" PAS direction signal line. Or I suppose the thermistor input could be set as an output too, and then there would still be the ability to have a directional sense via the PAS sensor of your pedal direction so you could have a "backwards pedal to shift gear" option, kinda like an electrical version of the old kick-shift 2 speed hubs!
Yes, I experimented this even with the old CA-LRC, using Amp throttle and leaving that throttle residual...that's with an Astro 3220 4t and HV160 shunted/wired for the CA. It works great, Don't know why but the idling starts only while applying throttle the first time after boot up or setup exit, also with the LRC, that throttle residual is not dependent from the MinSpeed value, and not having e-brakes lines.....could be cool for a single track or a race...justin_le said:Yes, another feature that I've thought heavily about over the years . You can actually experiment with this now by setting up your system to have a power (watts) throttle and setting your min throttle input to be slightly lower than the actual throttle off voltage. So if your throttle is sitting at 0.9V, put your min throttle input at say 1.0V, so when you let go of the throttle it is at about 4%. If your max power is set to 1000 watts, then when you let go of the throttle it would still be commanding 40 watts from the motor, which is about what it takes to spin a motor unloaded. You'd definitely also want to have the ebrakes wired up so you can shut the motor off completely as well, probably via a handlebar on/off switch.
justin_le said:Another way would be to use the autoPAS mode with a PAS sensor, but have the PASWatts be your low double digits value to keep the motor spinning. Then at least when you turn the bike on it won't be putting a small amount of power through the motor. It's only when you are pedaling then the motor would spin up to speed to be engaged but not provide much power, and then use your throttle when you actually want power output.
If you have a setup and can play around with this first to see how it works, then that would help determine if it's worth including as a build-in feature. We'd add a parameter for "idle watts", and whenever the speed > 0 and the ebrakes are not pressed, then the CA would be commanding this small baseline power. Eliminates the effect of cogging torque in a DD motor so that it feels like a perfect freewheel, and keeps a geared or mid-drive motor engaged so that there is no transmission shock when the motor spins up to speed
justin_le said:....then the CA would be commanding this small baseline power. Eliminates the effect of cogging torque in a DD motor so that it feels like a perfect freewheel, and keeps a geared or mid-drive motor engaged so that there is no transmission shock when the motor spins up to speed.
Okay - this make much more sense than the 66% earlier reported.ebike11 said:I set the cells of my battery to 18 and Ah at 20,
When I select the chemistry, most of the battery types display 66V and some
types are less than 66V in the setup screen.
My real time voltage is 72V on the main screen
Does the voltage in the Setup> Batt>Chemistry have to match the voltage on the main screen??
This is nominally the number of cells in parallel (the 'p' value in 18s8p) times the single cell capacity (eg 8x 2.5Ah = 20Ah). However, this changes with temperature, discharge rate, age, and abuse.ebike11 said:Is there an accurate equation to find the Ah value?
I was told 20Ah by the seller but would like to verify
maybe i don't understand the question correctly, but i would just ride the bike until the bms cuts off, or whatever device you use to protect your battery (celllogs etc...) and then not down the Ah your ca shows you. this value is the best number you will get as it measured during a regular use of the bike.ebike11 said:Thanks a lot for explaining!!
I see what you mean
izeman said:maybe i don't understand the question correctly, but i would just ride the bike until the bms cuts off, or whatever device you use to protect your battery (celllogs etc...) and then not down the Ah your ca shows you. this value is the best number you will get as it measured during a regular use of the bike.ebike11 said:Thanks a lot for explaining!!
I see what you mean
imho the Ah input value is just to give YOU a gauge to show how much battery is left.
ebike11 said:Hi guys
Just test riding my bike and configuring my CA DPS
Sometimes Im getting a flashing "V" when increasing speeds.
Is it warning me about my voltage? The battery is charged 90%
Also with my Cruise setting to 8sec, sometimes my throttle/motor automatically
goes into cruise when I didnt expect it to, at low and medium speeds it kicked in.
Perhaps it has to do with Throttle Input and Output settings??
Thanks!!
.) profilesNeilP said:I have a large screen V2 here, and also a V3...but for this bike I am not using a torque crank...just a throttle and e-brakes , no pas or torque sensor....
Any advantage to using the V3 ?
Hey Neil!NeilP said:Max 10k for R1, makes me think 9.1k and 200k So scaling setting of 25.17v/v would give me the required voltage range, giving a max VBatt of 114
Or am I better off with a lower R1, so 8.2k 180k
Or lower still ... 7.5k / 150k and max VBatt of 105?
NeilP said:If I am understanding correctly, on page 33 of the Unofficial User guide
http://www.cycle-analyst.de/Cycle_Analyst_V3_Prelim5_UNOFFICIAL_USER_GUIDE.pdf
teklektik said:
- BTW - You noted this link:
NeilP said:If I am understanding correctly, on page 33 of the Unofficial User guide USER_GUIDE.pdf
Please do not do this - it hampers other ES readers who follow your link.
Please link only to the actual Guide distribution post in this thread (not the file).
hjns said:amberwolf said:For those few running the CA off 12V and using a separate battery voltage input like I am (and I think Hjns is?),
Not anymore I am. Some time ago I ran 30S and inquired about the CA accepting that high voltage. Justin answered that the CA can accept that no problem. Therefore, my CAv3 is still hooked on the controller using the DP. Later I moved back to 20S, so no reason to change anything for me.
I did fry a CAv3 when connecting it to the Thun, and then connecting it to the 20S lipo pack. As mentioned several times now in this thread, the CAv3 can not convert that high voltage to power the Thun, therefore, the Thun needs it's own 12V when using more than 10S as battery. I recently sent the fried CAv3 back to Adam at Grin under RMA. Fortunately, my other CAv3 is working quite well. Keeps my cromotor from overheating when climbing Swiss hills.
From my reading of the guide...get the latest from the link posted above...section 5.3eBrakesebike11 said:Hi
Does anyone know what ThrO > Brake Out does?
I check the guide but cant seem to find it.
Thanks
Some ESCs fault when the pulse width goes to zero so in those cases ThrO->BrakeOut can be set to a low non-zero value that is compatible with the particular ESC.
