hi--can i get some help with cycle satiator setup?
i have a 52 volt 20ah samsung 18650 25r pack.
how do i set the satiator up for both 100% and 80%?
i have no idea how this device works. i am completely lost!
In the upper right corner there is a search box, just beneath it there is a 'Using google search?" check box, be sure to do searches both with and without this check box checked as the results will be considerably different but both potentially interesting. Before starting threads I recommend always doing 10 minutes minimum of searching on a subject. A lot of questions come up repeatedly on this forum so I am hoping that by saying this enough the hijacking/derailing as well as redundant threads slows down a bit.
http://www.ebikes.ca/catalogsearch/result/?q=+cycle+satiator I don't know where you purchased yours from, but the user manual can be downloaded directly from the manufacturers website. There is also a thread on this device where your future questions have likely already been asked twice on the cycle satiator.
