steveo
anyone know how much amps can be run through them; i'm in the middest of doing a 100v 60-80 amp setup for my bike...
thx in advance ..
thx in advance ..
Ypedal said:75 vs 45 / 30 andersons !!!
The 75's are much more meaty !!!!!!
GGoodrum said:In the RC world, we have used the Deans plugs with setups that have had voltages up to 60V and current peaks of 100A+. The biggest proble I've seen with them is that when you first connect them together in these big setups, they arc pretty bad if not connected together quickly and smoothly. To minimise this, you have start at the bottom, with the vertical blade (the negative usually...), and then roll the upper parts together.
I've had some dead shorts that melted wires before anything happened to the Deans plugs, but the same sort of shorts melted the platic right off the Anderson PowerPoles (45A version...).
My bikes are setup for 66V and 90A. I use the Andersons for connecting sub-packs together and a Deans to connect to the controller. No problems so far.
-- Gary
