Hi All,
Hope everyone had a good Xmas and has a good new year as of tomorrow!!!!
I had a spare couple of hours yesterday for the first time in ages so i decided to charge the bike and see what was going on with my LVC - if you all remember i ran at 72v but after approx 2.5ah the bike tripped with LVC as one of the cells only charged to 39v.
I charged both the batts and again one charged to 40.8v and one charged to 39.2v?
i ran the suspect 39.2v cell by itself and sure enough after 2.5ah the batt tripped and that was the end of the ride on that cell.
I suspect that this battery was the culprit of cutting my 72v ride short previously but just to be sure i hooked up the 40v cell and rode on - this battery ran upto 3.5ah before i had to quit due to the untimely rain
but it felt stronger than the first and i'm sure it would have continued right up to about 9ah as it has done previously (i will run it again to check tomorrow).
So it looks like the batt that only charges to 39.2v is the "bad one" - weird thing is that when i was running 36v this "bad" battery although feeling very slightly less powerful than the "good" one always ran ok right up to 9-9.5ah???
All i can think is that it needs cycling a few times maybe to bring it up to full charge. Both batteries used to charge to 41v so would i be right in thinking that if i'm only starting with 39v that im hitting low voltage a lot earlier than if it charged to 41v?? i know it's only 2v difference but would it make sense that those 2v would keep me above LVC allowing me to get the "missing" 7ah of use????
Anyway will do some more testing tomorrow and see how it goes - if my cell is no good then i will be looking at having someone make me some A123 cells for the coming season
on the good side i checked out all the mechanical side of the bike and the vibration i was getting on the seatpost on the 72v wasn't due to the increase in power - i had left the shock loose!!!
still, all tight now and the bike is running smooth as silk once more - just need to sort out this damn battery now and i'm away !!!!
Still looking for the DC2 base bike, missed out on a kona stinky that was £300 for the whole bike the other day
going for a kona stinky 2002 with A123's uprated xlyte 50a and new puma
man that should be sweet!!
cheers all,
D
