Hi guys,
The title says it! How do we determine the way power efficiency is affected by multiple motors?
For a given Kv, maximum RPM no-load rpm won't change no matter how many motors are running. But since the weighted RPM is directly relevant to efficiency, this means that adding motors reduces strain on each motor as long as power fed is multiplied by x motor number.
So by adding motors and power, you raise the max weighted RPM closer to the no-load max RPM limit.
Have any of you already tried to measure it? This could be useful when used with calculation software (you know, Kv / voltage / gearing / wheel size ==> max speed).
