If you like, I can move our discussion in this thread into a new one for you, and link it here.
Nelson37 said:
I'm afraid if I have a throttle I'll just mash that baby all the time.
Not an uncommon result.
What I THINK I want is a pedelec road bike or hybrid with a throttle that's like the morphine button I had in the hospital, only works for a brief interval and then you have to wait before you can use it again.
Well, that's relatively easy, but would require a bit of added electronics. A very small and probably very simple "one shot" 555-timer based circuit could pretty easily do that. It'd be "charged up" by any voltage being present on the throttle signal output wire, and then when it reaches the time limit it'd turn off the power to the throttle itself. Another timer would then control the reset of the first timer so you could use it again later.
I don't know any systems that do that by themselves, though, so that part you'd probably have to make yourself (or have made by someone).
I would like to get my cruise up to say 15-18 with a bit less effort, with maybe some assist available to 20 or a touch faster, and able to cruise on motor alone around 15mph, or again just a bit faster. Don't think I want or need to exceed that 18-22 mph ballpark. I've spent some time with the simulator but I'm still kinda undecided. Q-100, MXUS, or Justin's mini seem in the ball park, even maybe a 350W Mac.
Pretty much anything can do that sort of work under the conditions you have listed. The old original 36V Fusin I've got (had, will have again) on DayGlo Avenger could, easily enough.
The battery will be the one thing you really want to ensure you get right for your expected range/power usage/lifespan, though, cuz it's the hardest and/or most expensive thing to deal with problems on later. Controller and/or motor is relatively cheap compared to that.
Most of the geared motors will probably be a little noisier than the direct drive hubs, but probably physically smaller (at least in diameter) than the direct drive for the same startup torque under the same power levels. However, becuase of their "double layer" construction, they don't shed heat as well, so if they are run above their design specs they can get pretty hot (sometimes with no permanent damage, sometimes otherwise). They are also more complex and potentially could fail easier than a direct drive (DD) hub, simply because there are more parts in the path from motor to wheel. The latter is also true of any middrive.
I've used all three, and experienced failures with all of htem, but I'm also abusing them all a fair bit.
Most poeple don't see failures at all, with any of them.
Some of the RC-motor friction drives seem to offer something pretty close but the noise is not something I can deal with.
The quietest thing I've used has been the DD hubs, but most of any systme's noise is during accleration or while more current is flowing thru it. But they've all got their little noises, and some are less irritating htan others. Supposedly certain motors like the old TidalForce and it's successor(s) are silent because of the actual motor design, as well as controller type, but they are (AFAIK) only avialable used, and I don't remember anywhere that still makes parts for them if something goes wrong, so you'd have a DIY repair to deal wiht in that case.
There are some controllers called Sinewave (search on "sine*", whcih use a slightly different way of sending hte current thru the same old motors to be a little or a lot quieter, depending on conditons and design/etc. I haven't yet used one to see how much difference that makes.
Pretty sure I want a small geared hubbie, and either buy pre-made or deal with Cell-man or Justin. Then put on the front with the batteries in the triangle. Steel fork with dual TA. I've read enough to know that Cell-man or Justin is a good idea, and front motor may, or may not, be a bad idea.
Remember that in general anything in the back is quieter than in the front just because it *is* behind you.
Also, you get more traction out of anything in the back because more weight is on that, except during braking. Under wet conditions it may be easier to use a rear motor because of power in turns, especially with PAS, because sometimes if you have any power on the front wheel it begins to slide and skid and could cause a crash, but if you only apply power to the rear wheel then it's ok. (sometimes leaning forward over the bars will put enough weight on the front to fix it, sometimes it just unbalances you and makes the crash harder). With PAS, then pedalling to apply power in back will also apply power in front, and depending on how your system is designed there could be a significant delay between starting to pedal and getting power, and also a delay in stopping pedalling and having power stop being applied (that's the more dangerous part in that particular situation).
It's harder to service the wheel in back, though, more on some bikes than others.
Batteries to hit 25-40 miles don't seem real feasible with an easily pedal-able bike, but battery plus human input should work.
yeah, even light bateries are heavy. IIRC it's about 20-25 pounds including hte 50-cal ammocan case for my CrazyBike2's 30-ish-mile range pack (flat terrain, little wind, no pedalling, 20mph cruise, 15-18mph avg speed, hard startups). Add about 10-12 pounds for the other 10-15 miles of the "reserve tank" that's usually paralleled with the main one.
When I was much younger I saved and researched and read for two years, and finally bought ......... A LAMBERT. The "death-fork" bike. So I'm being a bit anal about gathering as much info as possible, but every new piece of info leads to new decisions and options. At least some of them are starting to make a little bit of sense, but then something new comes along.
Understandable--I remmeber reading on Sheldon Brown's site about that bike. :/ Hopefully yours didnt' actually break on you! FWIW, I had the stem snap on my Columbia 2005 bike, before it became DayGlo Avenger, within the first month of riding it. Almost broke my shoulder...very lucky I was wearing a helmet, too. It's hard to steer when the handlebars are no longer connected to the bike!
Like when you said "specially designed for PAS" I was thinking there might be something different about a "PAS motor" as opposed to a, well, "non-PAS motor", in terms of design or something.
[/quote]
The motor itself usually is the same in either situation, with the exception of some systems like BionX, where the controller and the sensors are actually integrated into the motor itself.
It's usually the controller that would need to be PAS-compatible, and which type it uses and how it works depends on that.
And of course, there's the CA v3 from Grin that can use various types of PAS sensor input and translate that into a regular throttle output for any throttle-compatible controller, so you don't *have* to use a PAS-compatible controller (but as a whole if you don't intend to use a CA then it's cheaper by far to just use a PAS controller).
The nice thing about BionX, and systems like the CA v3 with a THUN sensor, is that they actually sense how much torque you are putting out by pedalling, and can control the motor's output based on that, essentially giving you "bionic legs".
That's the way I'd prefer systems to work, and how I originally planned CrazyBike2's powerchair-motor-driven-drivetrain to operate, though I never got that far with it.
Most of the cheaper PAS stuff at best controls the speed of the motor by the speed of pedaling, and at worst just turns motor on at full power when pedaling and off when not.
The only PAS I've actually gotten setup and tested on my own bikes has been the newer Fusin 1000W system, which is reviewed and explained over in my thread for it in the review section (and also linked in my Delta Tripper thread, but I did not install the PAS for it on Delta Tripper as I didn't like how it worked).
All that said: in that situation I'd personally go for a smaller regular throttle system in the 350W range, and a CA and THUN (or other torque-sensing) BB sensor to give me the PAS capability. Then I'd build that timer circuit or something like it to prevent the overuse of throttle. (or alternatley, put a spring-loaded button on the left handlebar that is really hard to press so I cna't hold it down very long, that must be pressed in order to have the throttle on the right side work).
With the CA the response to PAS input (and throttle) can be adjusted to your taste and purposes, and if you like you can change it on the fly when out and about to suit your momentary needs, too.
Battery size, well, that depends on hyour weight limit for that, and the range you can live with, and the money you have for better lighter longer lasting cells. A123 or other LiFePO4 types are nice, but they are significantly heavier than the same amount of Wh in NMC or LiMn, etc. I've got both, and they perform similarly on my setup but I get less range out of the same-sized but notably heavier A123 pack than I do out of hte NMC pack.
Others will have more specific advice about various components.
