dnmun
1 PW
i have a small 3A ping charger which has a small diode in the back end that supplies the current for the fan and the opamps and led from a winding on the transformer separate from the one that supplies the schottky diode and the current to the output.
the diode has burned up and so there is no circuit current for the back end so the charger is dead.
i am trying to mentally determine how to size the diode in order to buy a replacement.
the fan is 12V, the capacitor is 50V so i know it is in this range, and the opamps cannot handle more than 20V i assume.
if i choose a 20V diode, i assume i will miss getting as much power from each cycle as i would with a 15V diode. but i do not know how much current is needed to drive the fan and the op amps along with the led. i doubt if a few volts is gonna affect the led, or the opamps but the fan will need a lot of juice to run so that is where i am mentally now, figuring the load part for the diode.
i am looking at 15V 5W diodes now off ebay since the shipping is so cheap from hong kong. but i don't know if 250mA will drive the fan.
i am gonna check the voltage on the output of another charger to be certain of what i need, but i wondered if there is a procedure to follow to determine how to size the diode i need capable of handling the power.
and if someone has already had to go through this exercise or knows the part, i would appreciate that input too.
