kylerlaird
How does the signal get to the controller with cable-operation. Would you post a link please and thank you.really cheap metal ATV thumb throttle that pulls a cable-operated throttle body
GREAT learning for me, thank you!too many attempts
Same way as any other throttle--the sensor unit is wired into it just like a regualr throttle. The only difference is that the sensor unit is not inside the handgrip or thumb unit, it is a little box that is operated by a cable pulled by the handggrip/etc.How does the signal get to the controller with cable-operation. Would you post a link please and thank you.
The only reason I would do it myself now is if it were some OEM unit that can't be replaced with generic for some reason, or one with some function or form that isn't available in any other unit, pretty much forcing a repair situation.It seems that an ebike throttle is such an inexpensive part, why waste your time taking it apart.
They do make those...Magura, Domino, and a few others, including some cable-pulled (cable operated, COT) throttle "boxes". Just not something you'll see on the average ebike--the pot throttles are either more expensive for the good ones, or poorly made for the cheap ones, in the latter case it's better to have a cheap hall throttle as it's less likely to fail simply from it's cheapness.I expected to see some sort of potentiometer, but I only saw a little piece of metal and a bit with wires to it.
