heathyoung said:
Wow - thats pretty much what I had in mind, its an unisolated buck converter. Ground the negative.
Actually, the midpoint of the DC link is set to be earth voltage, either through the neutral in 120V input, or the center of the two phases in 240V input. Grounding the negative terminal of the charger's output will short the negative rail caps
with no fuse in the path. Both output and both input terminals should be fused.
Pardon my ignorance, but I don't understand what parts of their design are "fashionable" or "blingy". What are you guys referring to? Aside from the fusing violation, I really don't see how it's all that bad. In light of what the auto industry is doing with the SAE J1772 connector system, I think it's awesome!
