What's the specific reason for changing the display?
(sometimes the part someone is looking for isn't the part that's causing their problem, when there is one, and sometimes the reason they want to change or upgrade a specific part means that isn't the part they need to change)
It's unlikely that your present controller/display would be compatible with a new display/controller, so you'll probably have to change them both out.
What specific features are you looking for?
If you don't know, then what specific features does the bike's motor / assist system have now that you would like to continue to have?
If that doesn't matter, then my best recommendation would be one of the KT KunTeng (or LS LiShui) controller/display combo kits that matches the voltage and current limit of your present system. They're not the cheapest thing out there, but they are fairly well-known and documented.
Note that regardless of what controller/display combo you get, you will probably have to cut and splice the wires to the rest of your bike, unless you can find one that matches the specific connectors and wiring order that your existing controller has. (not shown in your picture or described in your post). This may require trial and error, or tracing out and drawing up your present wiring (each wire in each cable) to be sure to match the new controller/display up to them.
