John in CR
100 TW
REdiculous said:if your battery is 48v 12a, total desity is 576watts right?
No, that's 576 watt-hours if your math is right.
edit; 576 watt-hours is equal to 2,073,600 watts...
If you really want to use watts/km, you can, but the numbers should look a lot different. If you use 20 watt-hours/km then you could also say that's 72,000 watts/km.:wink:
That's 2 million watt-seconds, not 2 million watts. FYI 1 watt-second = 1 joule = 1 newton-meter. The joule is the proper unit of energy for most situations, though the calorie (4.1868 joules) is fairly common too, but the watt-second/joule/newton-meter interchangeability is far better to make sense of things. Too bad they screwed the pooch regarding time. If a minute was 100 seconds and an hour 100 minutes, then things would really be easy as long as you didn't work an 8 hour day, since the day would be only 8.6 hours instead of 24.
