neptronix said:
You've always pulled the majority of the weight here amberwolf.
I doubt that. There's lots of others doing it, too. Just to name two off the top of my head, Dogman answers so many questions I wonder how he finds the time, and Miles so often has instant answers and references and links that some of us have had the thought he might actually be an AI search engine.
Jeremy Harris and Bigmoose do some serious technical support, you and Dnmun and a host of others keep helping with the troubleshooting threads, etc.
I just want to make it take less time for all of the helpers to do their help, so they have mroe time for other things (themselves, helping more poeple, etc), or even jsut to reduce burnout.
I remember you even helping me out as a total dumb newbie.
If there were only two of you
THAT would be scary, you know. :lol: But I often wish I had two or three times the amount of time that I do, especially the last two or three years, which have left me more and more tired and less able to get up and do things, instead of just talking about them, which is often all I manage to do some days after work.
I wish you had more control here. I think the thing is that the upper management has always been 95% absent.
I don't think me having more control would be a good idea...even if I did I trust myself little enough that I would have to make polls and whatnot on just about everything regarding changes...and nothing would get done then, either, probably.
Anyhow, AFAICT "upper management" is pretty much mostly absent from most places I have been to, either physical or virtual; some of them do fine and some don't. I think the key is not having upper management be around, but rather having the tech support or tech admin around--and *that* we definitely don't have. MRVass is, AFAIK, the main person that we need around to implement and fix/change things, but unfortunately he seems to have extremely limited availability for whatever reason.
Various people have already found solutions to assorted issues, but none of them can be implemented without access to the server and/or backend of the administration stuff. Until he is available to do that, we're stuck with what we have.
So, for now, the best we can do is what I mentioned above--keyword/sticky the various threads/posts that have the info so it can be found in searches, and/or copy it to the wiki (especially the latter!).
I write PHP and design databases for a living. I have even started a forum in the past. I just got done writing a search engine for a mid size company. A lot of what i focus on in my web development job is information organization and presentation.
Well, if you've got any code that would help fix the search engine and/or indexer in PHPBB, or a replacement, then if we can ever get someone with access to the backend to install it, that would be really helpful.
I know others like Kingfish have also volunteered to write fixes, such as a translation bit to autofix the conversion failures in various posts from when the board was moved from place to place, where PHPBB has mistranslated characters repeatedly into things like A*a~*#%@(*AA or whatever (you know what I mean
). But we still have to have someone with access to actually install/run these things, and to backup the databases first in case soemthing goes wrong.
