Hello
I'm using an ebike contoller to control a hoverboard wheel brushless DC
this is my controller
48V-60V-64V500W30A
I'm using hoverboard battery 36V
I connected the following wires :
RED wire Electric Door Lock -> connected it to + of the battery
BLACK & RED POWER CABLEs -> to the battery
HALL SENSORS & MOTOR PHASE -> to the hoverboard wheel
learning wires -> connected them with each others
After doing that the motor starts to turn but when i plug out the learning wires, it stops
even i connected the throttle
I tried many ways to controll the wheel
I connected an ebike throttle to controller
I gave the throtthe signal a PWM signal from an Arduino
I gave it a PWM signal after passing from a RC circuit
I gave it the red wire directly
but nothing works and the motor doesnt turn when i plug out the learning wires.
I didnt connect the following wires :
THREE SPEED
Metre Wire
Anti theft & Anti shelf
Cruise Speed wire
Brake Signal High
Brake Signal Low
Thank you !
48V-60V-64V500W30A
THREE SPEED
Metre Wire
Cruise Speed wire
Brake Signal High
Brake Signal Low
Thank you !
