ElectricGod
The chain line is finally done! It shouldn't have been this hard, but it was. I made 3 wood mock-ups and tried different places on the swing arm. All of them had issues. I finally went with a smaller roller and that fit in this location nicely and solved all the issues I was having with running into the swing arm with the roller or the chain. I've spent several days now trying different rollers and tensioner locations. It took a loooong time to get the chain line right, but it's silky smooth, dead straight and doesn't interfere with anything now that it's done.
The final tensioner took several hours to make and tweak, but it's rock solid and works perfectly. The 3 holes need to be elongated so that it will slide up or down the swing arm a little as the chain stretches and it needs to be painted. Otherwise it is finished.
This location gets the return side of the chain away from the swing arm. Having the chain graze the swing arm was causing me lots of problems.
