Ultraman
1 W
The large inter-city train and bus company in southern Ontario, GO, installed bike racks on their buses about 2 years ago. They recently started enforcing a policy that electric bikes of any kind aren't allowed on the racks. This complicates my commute a fair bit, and it's a stupid policy in my mind, so I wrote an email trying to get them to change it.
Let me know if you've come up against similar "blanket" policies where bus companies see all electric bikes on racks as bad. The letter's below, and I attached a photo of the bike. I'll post again if I get a reply from them.
ELECTRIC BIKES ON GO BUS RACKS
I am writing as a customer to ask you to explain and, if possible, reconsider your policy on electric bicycles and bus-mounted bike racks. I am a regular GO user, travelling from Toronto to Hamilton several times per week. I genuinely appreciate the addition of bike racks to the front of GO busses over the past few years. This has allowed me to extend my commute by bringing my bike onto the train, transferring it from to bus, and riding from the station to my final destination. Admirable bicycle-friendly efforts such as racks and dedicated bicycle locking areas at stations prove the commitment that GO shows to sustainable, low-emission transportation.
Recently however, it appears as if a no-tolerance policy is being enforced around electric bicycles traveling on bus-mounted Byk-Rak carriers. When asked, drivers have various explanations for this policy, including “They’re too heavy†and “Public safety.†Each reason is valid of course, although it appears as if the policy is being applied without attention to distinctions between different types of electric vehicles.
There are two basic types of electric bicycles. Electric scooter-type vehicles have small wheel diameters, are heavy (generally over 100 lbs) and form factors that do not lend themselves to loading or unloading from a rack. In contrast, “regular†bicycles can be converted to use an electric motor. This involves installing a motor, small electrical controller and wiring onto a store-bought bicycle. This conversion will typically add 18 pounds to the bicycle weight. Battery systems are then added, which can vary from 5 to 20 pounds when installed. Battery systems are removable and can be carried by the rider.
The bicycle I take on the GO is a converted bike. It weighs 48 lbs, reflecting the 30 lb weight of the bike and 18 lb weight of the motor system. I have attached a photo of the bike to give you a sense of it’s appearance. The large hub on the front wheel is the motor. I can provide higher resolution photos if needed. Here is a link to the vendor where my conversion kit was purchased: http://www.e-bikekit.com/.
The system used by GO to carry bicycles on busses is the Byk-Rak, also used by a number of municipal transport systems in Canada including the TTC and HSR. I would draw your attention to page 7 of the Byk-Rak manual (http://www.byk-rak.com/pdf/Byk-RakManual.pdf) in which it states:
Technical Features Con’t Advantages
• The Byk-Rak is constructed to support over • This allows the carrier to easily hold heavy
250 pounds in the deployed position. bikes and provides for misuse.
I recognize that the practical tolerances for loaded racks would be less than 250 lbs during sustained use, although again the bicycle I am riding (and the vast majority of converted electric bicycles) weights under 50 lbs.
Regarding public safety, I cannot think of an reasonable argument to restrict converted electric bicycles from being carried on racks. There is nothing inherent to the motor system that is dangerous in any way. There is no explosion risk, no toxins, no risk of shock and the entire system is permanently fixed to the bicycle with metal bolts.
My aim in this email is twofold. I would ask you to reconsider the policy disallowing all electric bicycles on your bus-mounted racks, recognizing specifically the distinction between converted vehicles and purpose-built scooter-type electric bikes. Secondly, I would like to resume bringing my bicycle on my commute. If you could consider sending me an email or letter exempting my low-weight electric bike from the general policy until such time that the policy is changed, I would appreciate this.
Sincerely,
> signature removed
Sincerely,
> signature removed
