fechter said:Looks cool. Has a real retro look with the brown tires. Personally, I like the raw metal look of the frame and battery box but it should have some kind of paint to keep it from rusting. Could use clear :wink:
The downtube is going to have a lot of bending stress on it, so better be some thick stuff or it may fatigue and crack later. Much stronger if the tube was straight and triangulated.
The front tire looks like it will come really close to touching the frame if the fork is fully compressed. OK as long as it can't touch.
If it had pedals, it would be legal most places as an ebike. Laws vary widely from place to place. In California, it would be legal as a "Motor Driven Cycle" without pedals.
fechter said:OK, good explanation. I have seen plenty of moped frames that use a single heavy tube. A good test would be to use a string or wire to measure from the swing arm pivot to the head tube and put your full weight on it and see how much deflection there is. The tube sounds heavy enough to stay in the elastic range.
If you keep the speed reasonable, you should get really good range out of that battery. The metal box is also good for fire safety.
Is the PhaseRunner going to get a cover? Seems like it would get some road spray from the tire.
fechter said:It's the connectors going to it that are prone to water ingress.
sjofels said:That is why all the connectors are in the "tank", which does not show very well because of the wires still need to be tidied up![]()
neptronix said:I like that frame a lot. It's super cool.
Yep, 2 in fact 21mm outside diameter 12mm inside diameter, 800n load a piece.Chalo said:Does your swingarm pivot have a bearing in it?
You are probably right..TilmanBaumann said:Honestly, go all the way with the retro look. You are too deep in it already. Go full hipster :lol:
I think it will look good.
I would like to think it is because I built it from the ground up, rater then take an existing bike or moped frame.armandd said:Wow!![]()
Your retro theme truly stands out among the others here in ES. I wish there are more e-bikes like this.
fechter said:It's looking great.
What about some fancier foot pegs? Simple is good, but something like this would be a nice touch:
sjofels said:Too chrome for my taste, but thinking about maybe slapping on some denfeld (functional and no BS) ones in the distant future, first some other areas need my attention (LOGO!!!)
sjofels said:I would like to think it is because I built it from the ground up, rater then take an existing bike or moped frame.armandd said:Wow!![]()
Well I'm hoping to produce in some future (or lala land, who is to say)
Thanks for the kind words, it means a lot.
armandd said:Many of the e-moped build here looks either like a motor cross or the stealth fighter/bomber, which looks rather boring. :lol:
fechter said:Those look good. All my '70s vintage motorcycles had rubber pegs like that.
I'll be interested to see your logo :thumb:
