My second ride got much more pleasant. Instead of using mode 4, i used mode 5 accelerator only on steep gradients, assisting with some relaxed peddling and the motor held the pace without power loss this time. It seems that for 100+ kilos charge, it s preferable to use the accelerator to keep a steady motor speed.
I did a few other adjustments : V shaped handlebar (+3 inches) and a thicker saddle, and i m now starting to seriously enjoy the ride. Little adjustments make all the difference. Inflating the tyres from 1.5 bars to 3 bars also helped a lot with stability on asphalt.
A few suggestions tho to improve the overall experience :
the speed magnet would be safer placed on the rear brake rather than on the spokes.
riding by night makes it a bit difficult to find the speed assistance commands. A small led light placed on the command would really increase confort.
A "pushing" mode would allow to push the bike on high gradients with one hand on the saddle, which is much more confortable than handling both sides of the handlebar.
A long bolt to allow to adjust the front light setting. Once you change the handlebar to a higher shape, the light and honk hub move loosely and there is no way to set it.
A small white mark on the battery plug side and hole side to find out quickly how to adjust both without using your phone light.
Showing the motor temperature on the main menu, to find out when to accelerate to cool off the engine...
I lent the bike to a few lighter riders and everyone of them got extremely enthousiastic.
That s all for now folks
Edit : If this was possible, may be a way to easily set in the menu the force multiplication applied on peddling mode would help heavier riders keep enjoying the mode 4 on steeper sections...
