Mihei777 said:
I made extra battery under so that area where travel of wheel is there is 2 and below 4 batteries top each other. Please see picture.
I use 29” fork and 27.5” wheel, so clearance is enough.
Attaching battery is so that below there is metalbar going into water hole and under nucular
Thanks for replying!
I have too many projects and the LiPo cells I bought to do a big battery turned out to be too big, so I will use them on another project, and get back to building a big LMX battery when I have time.
After seeing what Brian managed to achieve with his EM3EV triangle pack, I am confident I should be able to fit at least 2kwh in the main frame section, so that's what I will aim for instead. Maybe by the time I get around to it there will finally be some cells bigger than 3.5AH for 18650's or 5AH for 2170's to make it even bigger capacity.
Cheers
