E-S LMX 64 Bike Owners
These are my settings from a few years ago. I haven’t checked them for a while. I changed the PAS filter to 2 kHz and the PAS time out to 0.02. That fixed the power continuation after I stopped peddling.
Thanks Joe.
I mirrored your settings exactly...unfortunately no difference. I could have a setting somewhere else that is causing it...not sure.
I've also had weird issues in the past with motor config where I had to wipe all the settings and start again by 'restoring' settings from a modified backup where that section was cleared. Even a factory reset wasn't enough for that. So maybe this is the same....painful.
When I find time I might give that a try, but for now, I only get PAS to 25Kph :rolleyes:
Cheers
CD,I was just on the Nuculas site and see they have a new firmware. I downloaded it but haven't installed it.
I was in the middle of their configuration page and found that in each mode S1,2 & 3 there is a PAS disabled and a PAS scale 0-100%. Have a look to see what yours says.
Thanks Joe. Unfortunately my firmware already includes those settings and I've played with them a bunch with no improvement. :(
Unfortunately I think I may need to do a complete factory reset and re-setup all settings as a last ditch attempt to fix this.
Cheers
I removed my old 30mm motor and installed the 40mm motor yesterday. I removed the covers and swapped them. I didn’t want the LMX logo. Both motors look exactly the same. Both IPM. I couldn’t see a difference between a 30mm and a 40mm motor. Maybe I missed it.
Does anyone know what the difference is?
I had some issues. Firstly the screw holding the pulley in place wouldn’t come out. Had to drill it out. Then to get the new motor in. I had to remove the battery holder and lower plastic plate. Only then could I get the wires neatly back in. Then I noticed the new shaft is a bit longer than the old one. The pulley wheel wouldn’t fit flush with the bearing. It was because the washer has a large lip and had to file off about 4mm on the pulley washer. I’ll set up the new motor with a full auto setup and see how it works.
Hey Joe, my understanding is the difference is the stator width internally. 30mm vs 40mm. Good for slightly more torque and less heat which in turn means more power before heat starts sapping power. So far I do believe I notice these improvements, but it's hard to prove.
I didn't really have the other issues you mention. But I have removed/reinstalled the motor a few times before so that may have helped.
Cheers
LMX fantastic customer support. I’ve got myself into a bit of a mess. One of those Paws of the ratchet fell off and landed in the hub bearing without me realising it. When I tighten up the wheel. Well that was that with the bearing. To remove that bearing, the ratchet ring. 48T ca. 34mm outer diameter has to be removed. Try finding that tool. The one from white industries is 48T but 43mm inner Diameter. Anyway to cut a long story short. Adam from LMX has been amazingly supportive and is helping me by supplying me with a LMX built tool.
I’ll let you know how it goes.
LMX. Thank you. Terrific support. Would 100% recommend this company.
Bearing sizes rear hub are.
1x 15x32x9mm and 2x 15x24x5mm
Ratchet ring 48T ca. 34mm
With this ratchet removal tool the job took a few minutes. Many Thanks to LMX. Fantastic tool. The broken bearing tapped out easily and the new bearing are now in.
I certainly notice the difference. It's pulls much stronger than before. Love the 40mm motor. I don't have any stuttering.
This is how I did. I charged the battery to 100%. Then loaded my LMX 166 configuration and selected mode 3. Then did a full auto setup on the motor, and SAVE that to the controller. That's it. Many years ago I did it with a half loaded battery and some or no config and the bike was a lame duck. I re-did it with the LMX config and full battery and then it was back to normal. Since then I only do a full battery tune. I haven't tried to tune with the full blown configuration, but load them straight away afterwards and have no problems. Maybe that helps. I hope so.
Has anyone found a way to mount a kickstand to their lmx64? I see that the lmx64h has one, would that be compatible with a regular lmx64?
Snapped my HL belt yesterday. 2000km. Not bad. Installed a spare, so that's on, and ran the bike in full mode without a problem. I was wondering if the extra power had broken it, but I think now, after a ride, it was just unlucky.
I use that one. It fits without a problem. It doesn't need the special bolt that screws onto the shaft. Just the 4 screws. It's very stable and does a great job. Hasn't got in the way either.
Thanks! What rear fender are you using?
Zefal DEFLECTOR RS75. I added a stabiliser. I think it was this one. Cube Acid Stays for Mudguard Set MTB 65 extra long
Stops it flapping around. It does help to keep the bike a bit cleaner. Look at the back of the seat and the rear suspension.
Thanks for sharing all the previous info Joe. Notifications aren't coming through for me on this thread so missed all that till now.
I took the LMX out for it's first spin in a while the other day and noticed after the ride one of the bolts holding the belt guard/sprocket cover was loose. Trying to tighten it just resulted in the threads starting to strip inside the motor. :(
Before it got too bad I cleaned it out, re-tapped and used a new bolt. I'm 99% sure I got it right with M6x1.0.
Seems to be holding ok for now, but I wonder if others have had any trouble with the motor threads? I had the same thing happen on my previous 30mm motor and had to resort to a rivnut/nutsert replacement.
Cheers
Is the 500W mode street legal in EU/Norway with the 250W rule? Thinking of buying an LMX frame kit. A friend has the new Turbo Levo and stopped talking to me when I pointed out that he probably has more like 720W peak and 660W continuous. I guess when the importer test it they pedal (by hand?) with mininum torque and this is why it is still 250W. Or maybe it is not tested at all. The law is so poorly written that with some finesse you can choose to interpret it as the bike should not have a motor that will not break over time when subjected to an effect above 250W, which is completely untrue for every e-bike sold in Norway, thus making every e-bike illegal. I suspect the police knows about this and will only test max speed of 25km/h.
They call it nominal 250watts. Which is a power which can be held over a long period.
Here this is what specialize write.
All full power motors provide 250w of nominal output. "Nominal" means the power output that the motor can maintain over a defined period of time in a standardized test. Depending on the specific motor type, a full power turbo bike will provide the rider with 400 to 560 watts of peak power.
I actually called and the sales guy at Specialized admitted that the torque sensor has a lot to do with it, meaning during the test for the certification they make sure that the motor does not produce more than 250 watt, except for when putting a lot of pressure on the torque sensor, which most likely does not happen during the certification procedure. Otherwise they would also measure 700+ watts like Lunacycle measured during NORMAL use. Not use during certificiation.
Which motor here is recommended for the controller Nucular 12F and the battery Lunacycle 52V 17.5.
I would like the width to be as small as possible.
Seller says SL120-50 SPM or IPM is the correct one, but I have read about 30, 40, 50 and 60mm.
I can’t go much wider than the original motor.
Guys, where are you buying belts?
Is standard optibelt belt is strong enough or it has to be optibelt delta chain?
I don't know if something bigger than 40mm will fit into a frame.
If you buying directly from sneli keep it mind that LMX has modded motors.
LMX have almost 30% lower RPM and also axel is longer (LMX 14mm, original fom senli 10,8mm).
It seems like the modds were made by Senlimotors. Seller claims 60mm SPM will be great with my Lunacycle Jumbo Pack 52V, 30A, 17.5Ah. Maybe smoother than the smaller models.
feel like im more confused then ever in which e-mtb to get. finally came across the LMX 64 this week online but gracious, goes all the way back to 2019 in this thread and the battery seems like the weak point at 850w. probably have to take sometime to look this thread over. Ive gotten zero responses back from LMX. prelaunch lmx 56 only has two options to choose from so youd be stuck with either choice. Then the website looks like you can configure or change stuff, and then when you go to buy from website it disappears from cart.
SEM company heard zero responses, but atleast Boxxbike will respond.
Hi All,
First post in 15 years!! as an old member of ES (old account account seems irretrievable) seems a few of the guys from way back now have companies andare making some great bikes?
Can anyone bring me up to speed on the LMX? are they still going? is Adam "bzhwindtalker" from the sphere? he always had jumpable mid drives.
if any owners would be kind enough to bring me up to speed that would be great, I am catching up on the thread, but it's looong, I'm just looking for some feedback on how this bike is doing, no posts for while so i'm hoping alls well and the bike is still available to buy?
D
Has any one had any issues with the rear triangle. I have had mine break twice, granted I do 35+ foot jumps on it. I have a Bomber cr coil on the back with a cane creek 550-670 lb progressive spring. It just seems to bottom out really easily. Any ideas
Hi.
You can try out these changes to prevent bottoming out:
Slowing down the compression damping.
Tighten spring collar to increase rear ride height.
Replace spring with stiffer one.
Just remember that going too far with these changes may have an adverse effect on the bike's handling.
Avner.
