thundercamel
Regular
All three bikes now have upgraded forks with suspension and disc brake mounts. Like wturber, I've always been able to stop with rim brakes, and my riding is usually just cruising the trails for the scenery. They weren't able to do a good emergency stop though.
Since I needed good suspension forks as the old ones were garbage on Prancing Pony, starting to bind up on StefEbike, and rigid on the Lynx, figured I may as well try some disc brakes out. As seen in the previous post, the Tektro HD-M290 with Shimano B01S pads was good enough for me to put on all three bikes. I had to make a 1200mm hose for the recumbent which was easy, but bleeding with Tektro's kit pretty much requires two people to hold everything together without hoses popping off adapters/nipples.
StefEbike now has the same SR Suntour XCM 30 fork as my Prancing Pony. The fork is definitely beefier than the original Zoom one it replaced. I had to cut the 180mm steerer tube down to 6.5"/165mm with a sawzall and nailed it! Painted it pink to match the old one and my wife cut up a vinyl decal on her Cricut which is pretty schweet. Built a front wheel reusing the original rear rim and a new Shimano hub for the disc brake mount.
I also made this post detailing strange behavior with the rear shock on the Lynx, and have replaced it with a DNM DV-22. I had to reuse the sleeves and nylon spacers from the old shock, which actually required some work for one of them! Thankfully I've amassed a fair amount of tools over the years. The shock is supposed to have 30mm of travel, but there's only 20mm before it hits the bumpstop, which the old shock didn't have. I could cut the bumpstop down some, but it's probably fine as is. Not including the bumpstop, I measured 38mm of travel at the top of the seat, and calculated 68mm of travel at the rear axle.
Also changed my Prancing Pony to a 203mm rotor with E10.11 organic pads.
Removing the bearing race the right way! Also got it hot with a torch before dropping it over the new fork.
